Question about Hitachi Computers & Internet
Sata 2 hdd how to set to master 400gb - Hitachi Computers & Internet
    Scholar:
  • 101 Answers
Sata devices do not work like IDE, they do not have master/slave. If you want to set it to bootable, you have to go through the bios. On most computers, press DEL while it is booting, then go to "standard cmos features", search around a bit until you find where to set the bootable device list, and set the 400gb to the first.
Posted on Jul 16, 2008
My Intel D915GAG mobo works OK with one PATA HDD. But when I try to connect a SATA HDD mobo behaves strangely: sometimes it hangs up sometimes windows (in PATA master) won't start What I...
Intel D 925 has sata 1 controller , therefor your sata 2 or 3 drive can be malfuncton with this old controller , pls connect the jumper to sata 1 speed limit position in your hard drive near the data connector
Sep 25, 2017 | Intel D915GAV Motherboard
What is the maximum drive size I can install on my SATA controller?
Looks like at least 400Gb see below.
Product Details for 5100 400Gb Desktop SATA Hard Drive This SATA Hard Drive is used and has been tested for proper functionality.
Dell Dimension 5100 400Gb Desktop SATA Hard Drive.
Hope that helps.
Feb 25, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I have connected my 300 gb sata hdd to my pc which already has a 160gb sata hdd set to master when i start up my pc they r both set to master but i am told sata hdds dont have master / slave settings
They don't have master/slave settings as only one SATA drive can connect to a controller, however some BIOS have a setting designed to facilitate older OS's like XP that don't always have drivers available for the newer SATA RAID controllers built into most mid to high end PC's. If this setting is enabled on your PC then they would look to windows like a pair of master IDE drives on a Primary and Secondary IDE Channel even though each has it's own dedicated controller.
Sep 21, 2010 | Western Digital Hard Drive
Seagate 400gb hdd st3400833as lc gets on powering up
it might be a bad drive also examine it and see if the are any bent connection pins if it not sata
May 08, 2010 | Computers & Internet
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Mar 23, 2008 | Intel Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
52 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
