Question about Canon MP610 Photo All-In-One Printer
The printer that supports my printer cannot be found
I have a mp610
i plugged it in and turned it on, and connected it to my computer - i get the message this device and work faster...
i put in the installation CD, i install 'easy install'
i open a word doc and ctrl-p i cannot not see it there
i got to printers and faxes, i go to add printer, i click on auto detect my plug and play i get no plug and play printer can be found
i got to start - all programs - canon utilities - my printer and i get the printer that supports my printer cannot be found
i double check its turned on and plugged it
can anyone help with this issue?
5 Suggested Answers
SOURCE: Canon MP210 with Mac OS X 10.4.11 problems with printing docs
Hi
I have OS-X 10.4.11 and had the same issue; any printing just spat out blank pages.
I installed the following driver which completely resolved the issue:
http://software.canon-europe.com/software/0029270.asp?model=
There's a similar one for 10.5 that I haven't tested, to be found here:
http://software.canon-europe.com/software/0028432.asp?model=
If you use 10.5 and this driver works for you, please let others know by posting here, too.
Good Luck
Draqul
Posted on Dec 22, 2008
Joed911
  • 4338 Answers
SOURCE: Canon Pixma MP610 Won't print but will scan and/or copy
Check the properties again, Then try to print a test page.
If that does not work go to this link and download and install the printer drivers:
Just select your OS:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15604
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 29, 2009
TEKUSER
  • 56 Answers
SOURCE: I can't get the wireless connection on my new canon mp190
I was reading from that canon printer and the only type of connection is usb no wireless found or network, but you can share your printer if you are on local network.
Hope this help
Posted on Jun 25, 2009
SOURCE: Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Posted on Jul 10, 2009
  • 7 Answers
SOURCE: Exact same problem as OP
Canon support was able to help me with this issue.
First, scanning with the MF Toolbox is only supported via USB, not across the network (scanning across the network generally does work but you need another application that supports it). Second, you must make sure that you have switched the device into USB scan mode. Press the Scan button on the device. If the display says "Network scanning" press it again until it says USB Scanning. From then on, scanning works beautifully.
Posted on Nov 16, 2009
How do I scan from the Canon MP610? When I put doc on glass and press scan and ok, it says to connect to the usb cable and turn on pc. My computer is on (it's a laptop.)
Dear
three defects may cause.
1- change usb cable to different port. (test the port of pc with using pen drive)
2-do replace with another USB cable.
3- printer may defect.
remedies- Try to un install and reinstall the printer driver and its software.
Besides these trained personnel required.
Thanks.
Feb 15, 2015 | Canon MP610 Photo All-In-One Printer
My laptop has CanonMP610 installed but when I click on print, I get a message that the printer is not responding. The printer cable is plugged into the computer and the printer works on another laptop.
  1. Unplug the Canon MP610.
  2. Click on the Start Menu, then Control Panel. Open the Printers, or Devices and Printers control panel. Find your Canon MP610 printer and Delete or Remove the device by Right Clicking on the device and selecting Delete or Remove.
  3. Restart the PC.
  4. When in Windows, plug your Canon MP610 in and wait for device installation to complete, or reinstall the CD drivers.
  5. Try printing a test page.
Feb 26, 2011 | Canon MP610 Photo All-In-One Printer
User manual printer mp610 wanted
Canon pixma mp610 is one of the best All-In-One printer which can turn your home in to an office. It has 4,608-nozzle print head and can print 4" x 6" photos with spectacular 9600 x 2400 color dpi resolution which is its maximum resolution. It takes some around 21 seconds for the same. canon pixma mp610 also has a provision for the memory cards. You may preview the images in the 2.5" TFT display.
Apr 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Cannot get scanner to work
Try to uninstall and reinstall the drivers.
Be sure that the device is not connected to the computer until the software prompts you to plug it in
Sep 26, 2009 | Canon MP610 Photo All-In-One Printer
Can I save a scanned image using MP610?
Yes. PIXMA MP610 is a multifunction printer that has printer/copier/scanner capabilities.
Just install the software and drivers supplied with your printer (or download them from CANON ) and connect the printer do the computer.
The printer sofware will guide you through the operation of scanning an image and saving it to a a file in the computer.
Below is a link to CANON product support pages, from where you can dowload the software and drivers for the printer and also guides and manuals.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelTechSpecsTabAct&fcategoryid=2610&modelid=15604
Jul 27, 2009 | Canon PIXMA MP610 InkJet Printer
Canon Pixma MP610 not connecting to scan
Had the same problem. Don't think it scans wireless; worked fine when I connected with USB cable.
May 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My canon MP610 printer is not responding after replacing ink
Try switch of computer and printer if not in printer list of printers. Unplug usb cable and start computer without computer connected. Them switch off computer again and plug in usb cable and then restart and after started switch on printer and Windows should find printer as a new connection and then you may need your driver disc to reset up.
Mar 17, 2009 | Canon PIXMA MP610 InkJet Printer
My Mp610 Printer is not detected?
You need Vista driver from Canon web site
Xp drivers cannot work on Vista.
Feb 22, 2009 | Canon MP610 Photo All-In-One Printer
Will a USB2.0 port installed after purchase support Pixma MP610?
Somebody might have been confused or perhaps there is was a different issue as well. USB 2.0 is backward compatible. The printer should work on either, but with decreased performance on the USB 1.0. The USB 2.0 PCI card is a true USB upgrade no matter your original config. Make sure your PC otherwise meets the min requirements for the printer.
Jan 28, 2009 | Canon PIXMA MP610 InkJet Printer
Can't enable Bi-directional support for Canon MP610
go to cannon website and download new drivers for windows 7. Had the same problem and this fixed it right up
Dec 11, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP610 Photo All-In-One Printer Logo
1,412 people viewed this question
old marine
old marine
