I unlplugged my mp3 without removing it safely and now its stuck on a message that says please connect player to PC. and i did and it doesnt reconize it.
    Novelist:
  • 167 Answers
Unplug your mp3 player again and reboot your computer. Once windows fully loads plug your player back in and it should recognize it. If your player won't recognize at that point run windows update and download all the latest updates and reboot again.
Also, try plugging it in to a different usb port on your computer (somtime that works for me)
Posted on Jul 16, 2008
How to unfreeze mp3 player? i
Please RESET the unit , if not connect the player to the PC and scan for virus. It will be best to remove all the files and format the memory , then load ONLY safe files back to the player as it must play without hanging up. Also make sure that the player is fully charged.
Nov 30, 2011 | Audio Players & Recorders
My RCA mp3 player model th1702-a wont work it says it has too much data and is shutting down how do i fix it without spending money?
Connect the player to the PC and scan the files within. If there is any virus/malware detected please remove all files and clear the memory.
Now reload with safe files and to only about 85% of the memory space of the player.
If there is a reset please also reset the player after loading with new files.
Oct 06, 2011 | Motorola Mobility M25 MP3 Player
My computer doesnt reconize my opal m4002a mp3 player, even after i downloaded the cd and everything. i own two of them and they both have the same problem
Please remove the entire drivers from the PC. Open control panel>programs and Uninstall. Now connect the player and see if the player is detected by itself. If not remove the player and load the driver and ONLY THEN connect the player as the prompt comes to the screen.
if not test with another PC or else there are problems with the player or the memory card.
Sep 06, 2011 | RCA Cameras
After running the philips mp3 player disk pc doesnt reconize it
Unplug the mp3 player from computer.
Uninstall all Philips software using the add/remove function.
Reinstall the installation CD.
Then and only then, plug the mp3 player into computer.
Dec 09, 2008 | Audio Players & Recorders
Mp3 player not working
mp3 player is showing a flash error message.Please back up the data and format the player.
Aug 29, 2008 | iLO (2 GB) MP3 Player
Computer not detecting
In order to force the computer to reocgnize the device so that you can run the Philips Device Manager and repair your player, Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 12, 2008 | Philips GoGear HDD075/17 MP3 Player
Sansa e280 not working
I had the same issue. Plug the player in your PC. Go to "my computer" right click the Sansa player. Go to Properties and then select the "tools" tab. Run the error check and the disc defragmentation
Mar 25, 2008 | SanDisk Sansa E280 MP3 Player
Mp3 player not reconize
Put the Clip into hold (left-side switch down!) and press the center button down while connecting the USB cable
Mar 15, 2008 | SanDisk Sansa Clip MP3 Player
Corrupt playlists
Connect the player to the power supply and PC.
Press and hold [Vol +] & [POWER] until player resets.
As soon as the screen goes blank, release [Vol +] & [POWER] and press and hold [Vol -].
Player should show the connection screen, but without the status line at the top
PC will recognise the player as a removable drive.
Once the PC says that the device is ready to use, open My Computer and player should be in the list. (GoGear)
Right click on the player and select format.
Tick the "Quick Format box" and make sure the format is FAT32, and click start.
When the player has formatted, safely remove, and power up. You will get an error message on the player saying "connect to PC".
Connect to PC normally and repair with Device Manager.
Feb 25, 2008 | Philips GoGear HDD6330 MP3 Player
Ipod connecting
That message just lets you know that your device has been disconnected from the computer by Windows and that you can now safely physically deisconnect it.
Jan 30, 2008 | Apple iPod shuffle Second Gen. Silver (1...
55 people viewed this question
 Grubhead
Grubhead
