Question about Xerox WorkCentre XD100 All-In-One Laser Printer
XEROX WORKCENTER XD100 NOISE
I AM HEARING A LOUD NOISE WHEN I TURN THE MACHINE ON, BUT IT WILL MAKE COPIES. CAN YOU HELP . I CANNOT FIND MY MANUAL
THANKS
    President:
  • 2,072 Answers
Most likely the fuser gear is worn. The noise is prominant in the right side toward the back I am assuming.
You can replace the heat roll drive gear itself, but honestly I would recommend replacing the entire fuser assembly. It is probably very very tight and would wear another gear out quickly.
You want to get that replaced before the drive gear on the main motor assembly wears out. It would not rewuire replacing that entire main drive assembly, But it is a real difficult part to replace.
Go onto google and do a search for The Parts Drop. It will be the first item to come up. CLick it on and call and talk to Britt.
He will have what you need for a reasonable price.
if you go that route and need instructions to replace that part. let me know. Its not very difficult.
Posted on Jul 16, 2008
I have a xerox workcenter XD102 with a J1 error. What do I need to do?
J1 code on the XD100 series means that your toner cartridge is empty. You will need to order in a new one or have your existing cartridge refilled. Refills run about $60.00 and new ones are in the $100 to $125 range.
Precisionroller.com has a very good remanufactured unit for $46.00
http://www.precisionroller.com/search.php?q=xd100+toner
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 is making a very loud repetitive noise and in the front door where the ink cartridge is there is a lot of black powder
That means you need to replace both the ink and drum units. What has happened is on the front of the ink cartridge there is a waste sump that has filled up, and in the process has backed up the waster auger in the drum unit. The noise you hear is the auger bowing and snapping from binding .
Feb 26, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
XD100 Won't work with USB
check the usb port boot computer and printer..or parallel to usb or usb to parallell try it..
Sep 14, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I have Xerox XD100. Machine is very noise. The noise is coming from back of machine. Sand like motor is turning but something is stock (can not moveThis motor look like suppose to move)
There is a small helix gear attached to the shaft of the main drive motor. It cracks or shreads on the inside. You will have to replace the main motor. Not real expensive or difficult to replace.
May 28, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox workcentre xd100 copier NO POWER
hi,check power cord if the power cord correctly connected the problem is power supply.
Apr 26, 2009 | Office Equipment & Supplies
Xerox XD100 does not work
When you saying No working , What Happens when you press the print Button can you manually get this copier to print out ?
Has it stop printing only ?
Feb 19, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Clicking sound and crumpled paper
Bad heat roll drive gear in the fuser. Very common problem.
Look up on google a business called "The Parts Drop". Ask for Britt, part is $13 or $14.
Aug 31, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
177 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
