Question about Sharp Microwave Ovens
Turn table has stopped working in sharp r-930cs
  • An Tran Jun 03, 2013
    Sharp R-930CS-F won't heat and no turn solution: * I found a solution on the net and I got mine fixed so I like to share with someone. Solution: one the door switch is bad. Use the volt meter to check for the function. REPLACE IT. It should be fixed for a few dollars. Check it out before to replace a control board (cost over $150). Waste money and time if it not fixed. Good luck. An Tran
  • Sharp Master
  • 9,086 Answers
We have the service manual for that model and have uploaded it to our site for you here.
Chances are the coupler or motor is bad.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
Sharp R-930CS-F solution for no heat and no turn on plate:
* One of the door switch is bad. Use a volt meter to check for a switch function. REPLACE IT AND IT FIXED FOR ME. Good luck.
Posted on Jun 03, 2013
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Aug 17, 2014 | Sharp R-1480 Microwave Oven
Sharp R-930CS microwave turntable stopped turning and neither convection or microwave are working (ie. not heating). Lights and fan turn on and counter counts down normally.
Look inside for one of many thermal cutouts (button type) test each for continuity (with the unit unplugged of course). Also look for burned wires and repair or replace them. If you get it running and it works fine... we're done. If it still acts up then replace the magnetron and or the capacitor.
Oct 19, 2013 | Sharp Microwave Ovens
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Jul 29, 2011 | Sharp R-1505 Microwave Oven
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
I have a carousel sharp microwave and it has stopped turning. The microwave still works, but it doesn't turn and doesn't cook as well (kind of uneven). What's wrong with it and can it be repaired?
Sorry to read about your problem, I hope this helps you out.
You have a defective table drive motor
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Sharp Microwave Ovens
My microwave door sags to the right from the top hinge. The microwave is a Sharp R-930CS. How do I adjust this?
The only adjustment is by removing the outer cabinet and examining the hinge side will be self explanitary.
Beware that the door must close squarely and if it is very mal adjusted will take out the mains fuse!
Oct 19, 2010 | Sharp R930CS Microwave Oven
Defective turn table (not working).
opening a microwave oven is not recommended at consumer level due to hazardous internal componants. Seriously hazardous.
Oct 27, 2009 | Sharp R-1214 Microwave Oven
Sharp Carousel R-930CS-F Wont heat
CHECK YOUR FUSES. IF GOOD IT MAY BE THE MAGNETRON IS BAD
Apr 17, 2009 | Jenn-Air JMV8000 Microwave Oven
I have a combi which I have had for some years model carousel1 and the turn table has become slow and at times stops I have purchased another sharp--delivered yesterday modelR-959M-but if the old model...
if you open it you will see a large belt that connects the table ,
it might be stretched or greasy. remove it and turn the table by hand . is it sticky or turns easy . gunk can be in the bearing surface.
Apr 25, 2008 | Microwave Ovens
Microwave Ovens Logo
375 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
