Question about Samsung CLP-510 Laser Printer
Dark Printing job
I have a CLP 510 and everytime I print it comes out dark black with no other colours. I have changed the cartridges, verified the settings in the print settings,and even printed the test page to confirm the problem. I don't know what else to do and I hope that someone can shed some light on what is happening here.
Thanks.
Cheers!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
This is normally caused by a defect in the high voltage charging of the Drum unit. Most of the time it is the actual OPC Drum ( the part that your toners insert into ), but occasionally it is a defective high voltage power supply.
The OPC Drum is considered a consumable with a limitted life expectancy and is user replaceable.
This SHOULD fix the problem, but if not, the HVPS would need to be replaced, and this would require an experienced technician to install it, as it is not a user replaceable part.
Posted on Oct 11, 2008
Samsung CLP-315 colour laser printer - is it true that you cannot print only with the black toner cartridge, if one or more of the colour cartridges is empty? I only need to print black!
Yes, it is true that most of Color printers will not allow you to print document if one or more of the recommended Cartridge of the printer is empty or removed from the printer. for printing only black, the better option will be to change your printer settings while printing a document. ex: when on a document ,and your press Ctrl+P for document printing, there is a option where you can select print color as black and the printer will print your document in Black only.
Feb 05, 2010 | Samsung CLP 315 Laser Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
Unwanted line down centre of page
you need to reassemble image unit and clean completely
if you dont know how to do just bring it your printer to technicians
Jan 06, 2010 | Samsung CLP-510 Laser Printer
The printer is printing dark vertical line on the
90% or more of the time on this printer dark lines are coming from your toner/drum cartridge. You can verify this by changing cartridges if you have a spare. If you don't then remove the cartridge and look at the colored cylinder in the cartridge and see if the same "lines" are on the cylinder that are on your prints. This will tell you for sure that the cartridge is bad.
Dec 13, 2009 | Samsung ML2250 Laser Printer
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
Loud irregular noise from printer during and after printing
This is the common problem of clp 300. you are required to change the black developer. for this you may approach authorised service center.
Dec 29, 2008 | Samsung CLP 300 Laser Printer
Colour balance
Looks like the printer's color profile has been changed. You can easily fix it. Open print preview and click show more options. And select a profile that suits you and print a test page.
Jul 07, 2008 | Samsung CLP-510 Laser Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP 6110 All in one
Various models do different things so you will have to checkout some stuff. 1. black is green- what it mean is if you take some black ink and wet it to dilute it will sh0w dark green then lighter etc., because black is all colours mixed. In most printers when a 'black' document is printed actually all colours are printing - take a look under a magnifying glass. Some printers however allow for 'black' only printing. But you have to set it up. So check your manual and software or what comes up on the screen. Then come come back
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Samsung CLP-510 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
