Question about 2wire 2700HG-B Router (2700HGB)
Linksys Adapter and 2wire router
Trying to connect to the Internet using wireless linksys adapter WUSB45GV2 and 2WIRE router. I get the message "can not establish the access point..."
This adapter was working with a linksys router in my office but when I brought it home, stopped working. Any idea? Appreciate it. Amir
  • Anonymous Dec 29, 2008
    I have a 2wire router which is not wireless and a linksys wireless router. I connected the ethernet cord from the 2wire to the linksys. I have communication with the linksys via my wireless laptop but no internet connection. I have internet connection when I put the ethernet cord directly into my laptop but it is not wireless. Please help!
  • 550 Answers
  1. ensure that a wireless connection is created in control panel on the pc, it may not even be attempting to connect
  2. ensure that the router wireless is turned ON, it may have been turned off as a security measure when no wireless pcs were used
  3. The security settings on the adaptor may be set to the office network and locked
    wep password at home is different or not enabled, so the secured adaptor will not connect.
make any changes from a cable connected pc (no chance of data loss)
access the routers settings page and check the settings,
then ensure the adaptor rom if present is set to the same settings
Posted on Jul 16, 2008
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
My Linksys network adapter is very slow to connect
Ask them to review you connection speed to make sure your getting the speed you ordered. Linksys is usually pretty good. See if it's faster WITHOUT using the wireless (plug directly into the modem). If it is I can only think of two things... Ether you need to relocate your wireless modem to acheive a stronger signal OR if your signal is strong on your adapters end, you could always upgrade to a different wireless adapter that can handle faster conections.
Jun 27, 2009 | 2wire (1000-400108-001) Router
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
first of all let's start from the complete facts, does your 2wire router have built in wireless or no? how you did the the cable connections between tht routers?.
Apr 04, 2009 | 2wire HomePortal® 1800HW Router...
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire capacity for wireless connection
yes you can return the linksys.
the following link should help you setup the 2 wire for wireless conneciton.
Dec 03, 2008 | 2wire (1000-000057-000) Modem
WUSB Linksys adapter connnection
check your dns value ,firwall,proxey server, ipaddress and router configuration also.
Jun 23, 2008 | 2wire 2700HG-B Router (2700HGB)
Win98, Linksys USB Adapter, 2wire router... no internet
hi!
sorry if it took a while to get an answer to your question...
anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
under network setting select obtain an IP address automatically (DHCP) & click on next.
under security settings choose "disabled" for WEP and leave the rest of the fields blank.
confirm the settings by clicking on yes.
note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection.
also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
please let me know if you have any issues... we'll work this one out, ok?
Apr 16, 2008 | 2wire (1000-400108-001) Router
2wire 2700HG-B Router (2700HGB) Logo
228 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
