Question about Maytag MZD2766GES Side by Side Refrigerator
THE CONTROL PANEL ON THE DOOR DOES NOT WORK PROPERLY
THE CONTROLS PANEL ON THE DOOR NEEDS TO BE PROGRAM THE DOORS WERE CHANGED HOW DO I REPROGRAM THE DOOR CONTROLS THE ICE CUBE BUTTON WILL ONLY DISPENSE CRUSHED ICE ANFD SOMETIMES THE WTAER DISPENSER OR ICE DISPENSER EVEN AFTER YOU REASE THE BUTTON IT STILL DISPENSE WATER OR ICE
    Champion:
  • 210 Answers
There is no program, replace the board.
Posted on Sep 14, 2008
How to check for a bad sensor on my MFI2569YEWO maytag fridge? We've replaced the control board in the back and display board in the door. the display reads PE0 000. Can't get it to program. HELP ME!
Patti when you change the main control board you have to reprogram the refrigerator to understand the board there is a code just below the model number and here are the instructions you need to follow them carefully
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word "Code."
1. Press and hold the Door Alarm Keypad .
2. Press and hold Freezer Temperature Down Keypad within 3 seconds .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).
Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
http://www.appliance911seabreeze.com/
Aug 09, 2016 | Maytag Refrigerators
Door ajar alarm keep beeping every 5 minutes and door is shut
was the replaced control panel a used unit
are the door hinges and seals ok
still maybe a faulty door sensor
Jun 17, 2016 | Refrigerators
Why is it stuck on PEO OOO?
Did you change a control board? Most times this happens when you change the motherboard and its not programmed for that refrigerator what we're going to have to do is get your model number and there's a code below your model number inside the refrigerator get me that and I'll try to help you find the instructions to reprogram your motherboard
Dec 01, 2015 | Refrigerators
I am in need of the proper programming sequence to enter the defrost cycle on a Maytag F/F model MFF2558VEM. The factory tech sheet is not on the unit
Lakeland Appliance: According to FixYa.com Jenny Dutot said: "Dear jorge, I had the same problem when my refrigerator was broken. You need to re-program the control panel as follows: 1. First you need the Program Code for your fridge. It is on the plate on the inside of your fridge, on the same plate that has your Model # and Serial # on it. 2. Programming is done with the refrigerator doors open. 3. Press and hold the Door Alarm keypad on the control panel. 4. Then press and hold the Freezer Temperature Down keypad. 5. Then release the Door Alarm keypad and wait 3 seconds. 6. The control pad will then display PE to indicate it's in programming mode. 7. Entry is confirmed by pressing the Freezer Temperature down keypad once more. 8. The control panel will display the current program code. It should be the same one that I asked you to find in Step 1. 9. If the program code is the correct one, exit the programming mode by closing the refrigerator doors. 10. If the program code is not the correct one for your refrigerator, press the Refrigerator Temperature Up or Down to change the value with each keypress. 11. The decimal point indicates the selected digit. Press the Freezer Temperature Up or Down to select the next digit. 12. Once the desired program code is displayed, press and hold the Freezer Temperature down keypad until the program code begins flashing, indicating that it's been saved. 13. Again, when you're done, exiting the program mode is done by closing the refrigerator doors. Hope this helps alot of people out there. I'm not sure what the problem is at Maytag, but they're extremely slow in getting parts shipped for their units. The local Maytag repair people have indicated to me that they are seeing an overwhelming number of Maytag refrigerators needing repairs that are around the one year age range. They say the quality of the new units is terrible. "
Apr 15, 2015 | Maytag Refrigerators
Why the freshfood compartment is to cold
There are 2 sets of controls on your refrigerator. One controls the thermostat The other controls a damper door that allows some of the cold air from the freezer to reach the fresh food area . It sounds to me like you are adjusting the thermostat when you need to be adjusting the damper door.The damper door (depending on the model) will have a mechanical linkage or a potentiometer( adjustable resistor control) and a servo motor that directly controls a door that lets more or less cold air in from the freezer compartment, you need to check the position of this control and door to see if it is working properly. If not repair the damper If it is working properly then you could have a defective thermostat.
Aug 01, 2014 | GE Refrigerators
Control on door has flasing lights, water and ice has stopped working
this appears to be the door switch is either bad or disconnected and has triggered an alarm mode to the display. If the unit is cooling ok then you should remove and check the switch with a meter.
May 29, 2014 | Maytag MFD2560HES Bottom Freezer French...
Replaced circuit board, refrigerator wont allow programming, just says PE0 000
Dear joe, I had the same problem when my refrigerator was broken. You need to re-program the control panel as follows: 1. First you need the Program Code for your fridge. It is on the plate on the inside of your fridge, on the same plate that has your Model # and Serial # on it. 2. Programming is done with the refrigerator doors open. 3. Press and hold the Door Alarm keypad on the control panel. 4. Then press and hold the Freezer Temperature Down keypad. 5. Then release the Door Alarm keypad and wait 3 seconds. 6. The control pad will then display PE to indicate it's in programming mode. 7. Entry is confirmed by pressing the Freezer Temperature down keypad once more. 8. The control panel will display the current program code. It should be the same one that I asked you to find in Step 1. 9. If the program code is the correct one, exit the programming mode by closing the refrigerator doors. 10. If the program code is not the correct one for your refrigerator, press the Refrigerator Temperature Up or Down to change the value with each keypress. 11. The decimal point indicates the selected digit. Press the Freezer Temperature Up or Down to select the next digit. 12. Once the desired program code is displayed, press and hold the Freezer Temperature down keypad until the program code begins flashing, indicating that it's been saved. 13. Again, when you're done, exiting the program mode is done by closing the refrigerator doors. Hope this helps alot of people out there. I'm not sure what the problem is at Maytag, but they're extremely slow in getting parts shipped for their units. The local Maytag repair people have indicated to me that they are seeing an overwhelming number of Maytag refrigerators needing repairs that are around the one year age range. They say the quality of the new units is terrible.
Apr 21, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Reprogram control board after replacement/ MFI2266AEU B/M REFRIGERATOR, M'TAG
Press and Hold Door Alarm Keypad
Press and Hold temp down keypad
Relaease door alarm Keypad and wait 3 seconds.
The control will display PE to indicate Programming mode.
Entry to programming mode confirmed by pressing FREEZER temp down keypad once more
The control will display the Current unit Programming Control code This code must be validated by comparing it to the Programming code stamped on the unit data plate (Model number plate)
If the programming code is correct all you have to do is close the refrigerator doors
To change the CODE press the REFRIGERATOR up or down keypad to change the digits.
To move between digits press the FREEZER up or down button. Decimal point indicates selection
Once the desired code is entered PRESS and HOLD the freezer temp down button until the CODE entered starts flashing.
Close the refrigerator doors or wait 4 minutes without Kaypad input for programming mode to exit.
That should be what you needed.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Maytag MFI2266AE Side by Side Bottom...
How do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Oct 26, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer
Mar 03, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MZD2766GES Side by Side Refrigerator Logo
271 people viewed this question
Top Maytag Refrigerators Experts
isaac johny
isaac johny
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
