By maartenw - usenet poster
Scanner was working fine until yesterday. Now when I do a preview of the
photo, the entire surface is black, or white. The phenomenon is
intermittent, but the frequency seems to be increasing. I am hoping that
you can provide me w/ some insight. Am I missing something obvious or is
the scanner kaput? This is my first scanner, I am using Vistascan32. I am
hoping that I am suffering from User Brain Failure so I do not have to deal
with tech support.
Thank you for your info.
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 31, 2008
scanner made black images
Best Solution
posted on Aug 11, 2005
Powe33 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The problem occurred while previewing and scanning. It has been working
fine for the past couple days. I believe that the problem was not with the
scanner but with the user (me) not fully understanding the significance of
changing the image settings. Thank you very much for your help.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Rachel007 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Just some thoughts:
Be sure that none of the image settings got changed or that you are in
line art scan mode. Check gamma, contrast, etc. settings. Maybe they
got set to the far end limits by something acting up.
Does it still scan ok and only the preview is messed up? What
operating system and did anything change(added new software, hardware,
etc.) at around the time this problem started?
On Thu, 22 Oct 1998 01:55:22 GMT, "Stone Soup" <cjbpr @mondenet.com>
wrote:
--Joe (replace nospam.net with prodigy.com in my address for E-mail)
http://pages.prodigy.net/bogo/
Suggest a new solution for this problem
Post a New problem for Umax Astra 1220P Flatbed Scanner
Email this problem
Email this problem
Can you Help with these Scanners problems?
colour of the scanned copy
when i use the scanner the... Answer This...
Need Driver for XP of Umax...
Hi, I will appreciate if you... Answer This...
Repair Service
Find Scanner Repairman Near You:
