Question about Whirlpool MH1160XS Convection/Microwave Oven
Won't cook but everything works like it should
Whirlpool MH1160XS, about a year old. I heated up chicken tonight for dinner, good and hot. Then the next use, no heating of food. Display, lights, turn table all work fine. Even cooked at 50% power, to listen for waveguide load to cycle on and off, heard that too. Unplugged the unit, waited, then tried again. No change. Thanks, Scott
  • 4 more comments
  • springerscot Jul 16, 2008
    correction, listen for MAGNETRON load to cycle on and off, heard that too.
  • springerscot Jul 21, 2008
    Great info, thank you very much. It is over a year old, about 15 months. Frustrating, pay good money for it for it to break so soon.
  • springerscot Nov 04, 2008
    I finally got of my lazy **** to pull the microwave out and test the magnetron. Ohm readings indicate a good magnetron. Terminal to terminal on lowest ohm setting is less than one, terminal to mag housing on highest setting is infinity. What now?
  • Anonymous Mar 10, 2009
    Same thing, everything works except for the heat. about 1 1/2 years old.
  • Anonymous Apr 23, 2009
    Same exact problem...
    I've had the microwave for a little over a year and about 2 weeks ago it stopped cooking. It sounds like it is doing something, but no heat. Lights, vent, timer all work.
  • Jigar May 14, 2013
    same problem, everything works except heating. it also don't turn off.
  • Whirlpool Master
  • 9,086 Answers
Good idea to run at half power. Good thinking. That can sometimes reveal an overheating magnetron.
Does it seem to buzz or hum louder than normal?
If so, you may have a shorted high voltage diode or a bad magnetron. If not, I only suspect the magnetron.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Whirlpool customer service is here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
Will not heat
If everything else is working fine, the magnetron is the likely problem, "heats food and is the heart of the microwave oven" if more than five years old cheaper to replace the whole item.
Mar 02, 2012 | Whirlpool Microwave Ovens
Some problem in poultry cooking
You have to kill the chicken first!!
Seriously what are you trying to do???, if it's cooking a whole chicken in a microwave, it is difficult to get a thorouh cooking because usually whole chickens are hollow in the middle, so you need to put stuffing in it to get a better performance as microwavs tend to heat in the middle of stuff, (air is hard to heat) try a stuffing with lots of moist (water) it will steam kook the chicken with a lot of flavour... remember to avoid stuffing that contains beens or seeds as they could explode inside the chicken and ruine a good supper... personally I prefer my chicken oven baked (all night at a low temp) I know I'm not GREEN by saying that I only use my microwave to quickly heat up left overs LOL!
Aug 10, 2011 | Microwave Ovens
This is now the 3rd GE to die on me in 10 years. Model is PEB2060dm1ww. Its a built in microwave Last night my soon cooks his dinner OK. When my wife went to cook her artichoke.. all seemed fine as the...
if out of warranty you can try a simple "fix" . some microwaves are made with a simple fuse on the inside of casing- should be able to remove cover with 4-6 screws and then locate fuse- DO NOT TOUCH ANYTHING ELSE! If in doubt replace the whole thing.
PS- if dusty inside ,use canned air(for computers or cameras)
May 02, 2011 | GE Microwave Ovens
My microwave is not heating but everything else works fine
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 08, 2010 | Whirlpool MH1160XS Convection/Microwave...
When I type in the time to cook food, the microwave will run for about 2 seconds and then turn off and beeb 3 times. what causes that?
Boy, this sure sounds like a GE with a failing leaky magnetron, but that's not possible since you posted this under Whirlpool MH1160XS.
But it may still be a bad magnetron...
Aug 19, 2010 | Whirlpool MH1160XS Convection/Microwave...
Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Mar 21, 2008 | Microwave Ovens
Whirlpool MH1160XS Convection/Microwave Oven Logo
314 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
