Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite washer flashes f20 and shuts down the machine
F20 flashes and shuts the machine down I can't seem to find the problem
  • 246 Answers
F20 is a "No water or insufficent water supply" error code. First make sure both of your valves from the house are turned all of the way on. Next make sure your fill hoses (the two macthing ones that go to the back of the washer) are not kinked. If both of these check ok, turn off your water supply and unscrew the hoses where they connect to the machine. There are 2 screens underneath that trap dirt and sediment so they don't get to your valves and cause them to run. If it's coated, rub the surface with a tooth brush or small flat head screw driver. Rinse with a little bit of water and repeat. If the screens are clear, check the hoses. Some hoses have the same kind of screens that can
be on either end of the hose. If all of these fail, you'll probably need to replace your water valve. Remove the 3 #20 torx screws on the back side of the top panel. Push the lid slightly towards the rear and lift up and out of the way. Next, unplug the connectors going to your valve (should look like light blue plastic and the hoses were hooked to it). There will be a 1/4" screw on the back panel holding your valve in place. Once removed,
you can slide the valve to the side and slide it out. The only part left is squeezing the clamp on the black rubber hose inside the unit to let the valve fully disconnect. While the water in this hose generally wont hurt anything, it also can't hurt to have a towel to catch the small amount of water in it. Replace the valve with one you've ordered online from the manufacture or purchased from your local appliance parts store. Re-assemble.
Posted on Jul 16, 2008
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer flashes F20. What can I do?
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first.
May 02, 2010 | Kenmore Elite 45986 Front Load Washer
What is the F 20 flashing warning light for on a kenmore elite washer
F20 = "Communication failure between EOC and ESEC system. Recommended action: Test harness/connections P4 (EOC) & P11 (Surface Element Control Board). If harness checks OK, failure can be caused by faulty UIB, surface element control board, or EOC."
Apr 28, 2010 | Kenmore Elite 45986 Front Load Washer
F20 message on washer kenmore elite HE5t
Feb 28, 2010 | Kenmore Elite HE5t Washer
My washer is flashing F20 what does that mean stopped during cycle and flashed f20
F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
89 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
