Question about LaCie F.A. Porsche (301177) Hard Drive
LaCie F.A. Porsche Hard Drive is no longer recognized
Hi, After years of use, I suddenly cannot access my hard drive. I am hoping to at least get the data from it. Can you help?
I get the error that the USB device is not recognized. I am running XP.
  • 1 more comment
  • uakbar Sep 10, 2008
    i connected my Hard drive to my mac but the iconn that use to come up is not there. I tried to hook it up to my PC but says ur device is not detectable. The LED on the front just keeps on changing between green and red.Any Advice ?
  • glitchcentre Sep 15, 2008
    I cannot access the most recent of folders on my lacie f.a porsche hard drive either. I copied some stuff on it, then after a windows xp home reinstall i cannot copy the info back to any laptop. some folders are accessible, perhaps the "protection" was switched on after these files were put on there.
    How can i get to the files?
  • Dave May 11, 2010
    Does it connect to another PC? Have you reinstalled any drivers it came with?
I was able to acces the hard drive again, by replacing the cable that goes from the hard drive to the computer. Once I did that, there was no problem with the connection.
However, some of the data seems to be corrupted or lost. Still trying to sort that out, but I did retrieve most of it.
Posted on Jul 19, 2008
My LaCie 500GB External Hard Drive stopped working. Before when I turned it on, I could hear it spinning but now all I hear is a clicking sound. When connected to my computer the computer no longer...
Sorry nothing to do your harddrive is dead. you might be able to open the case and replace the harddrive with a new one. Try searching google or youtube on how to do that.
Regards.
Mar 19, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
Jan 29, 2011 | LaCie (300728U) 250 GB Hard Drive
I have this hard drive. I've had it for 2 years now and now all of a sudden it won't open any files. its telling me something has timed out. The computer recognizes it just fine but will not open any...
1. It fails with your computer.
2. It works with your XBOX.
3. Find another computer, and connect it.
If it works, then YOUR computer is the problem.
If it does not work, then the problem probably is with the LACIE.
Aug 31, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
I have 2 lacie external hard drives that no longer work. They power up and I can hear it working, but they are not reconized on any computer.
Chances are, the IDE/SATA to USB/Firewire controller inside the device has died. You can take the case apart and take the hard drive out, and plug it directly into a computer through IDE or SATA, whichever it is. If the drive is recognized, then all you need is another external case to put the drive into. If it isn't recognized then most likely the powerboard on the hard drive or some other internal mechanical part is dead, and you would need professional data recovery to get anything off of it that you would want.
Apr 30, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Making Clicking noises and not being recognized by computer. This was all of the sudden and was not result of any trauma
I've had this exact same problem with a couple of LaCie drives.
The drive has failed. I would call LaCie Tech support (503) 844-4503 between the hours of 6am and 6pm (Pacific Time) to speak with one of their Technical Support representatives.
If it is still within warranty, they'll send you a new one.
This model comes with a 2-Year Limited Warranty - 1 year factory warranty for products bought before October 1st, 2007
Nov 22, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My LaCie is not recognized by my computer, makes a clicking noise when it tries to start up. I've used this external hard drive for several years with no problems.
It has most probably just reached its "end of life". Several years for a hard drive reading and writing is a good track record.
You can probably take the casing apart and replace the hard drive. Just make sure that this is an USB 2.0 interface before spending the money.
Oct 20, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Dear Sir/Madam I have accidentaly dropped Lacie mass storage device on the floor and when I tried to get access to the information it started making regular beeps + the PC can't recognize the device. Is...
It's not likely that you would be able to retrieve this data yourself, however, you might be best off visiting your loca computer specialist engineers who will be able to recover the information for you. Hope this helps :o)
Sep 01, 2009 | LaCie F.A. Porsche (301177) Hard Drive
When plugged in, icon doesn't appear on the desktop.
We have a few of these Lacie Design by F.A. Porsche 500GB drives in our office. Our editor's drive stop working this morning (was fine the day before) and had all her files backed up from the last three years on it and was making a very soft clicking sound. After taking the whole thing apart and trying drive in another F.A. Porsche caddy with no success, we tried a different power supply hey presto it started up no problems. My drive that suddenly stop working earlier in the year we tried a power supply from a external Lacie DVD Writer and again drive is working. Just to make sure tried the original power supply and would not mount. So if your hard drive stops working it maybe the power supply rather the the hard drive.
Jun 25, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Dead hard drive
Try unplugging the usb connector and plugging it back in. Your pc shouls recognize the installed component automatically. Also, some external hard drives work like normal pc's do: hold the power button in longer until something happens. Hope this helps.
May 24, 2009 | LaCie (300770) 250 GB Hard Drive
LaCie F.A. Porsche (301177) Hard Drive Logo
159 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
