Question about Refrigerators
Refridgration is not cooling - Refrigerators
  • sandang Jul 16, 2008
    Our refrigator side is hot inside. The roof inside was very hot. The freezer seems to be working fine. I unpluged it and move it to colder and now it seems to be getting cool and not putting off much air.
  • deepakmalhjo Apr 16, 2009
    I HAVE NOT COOLING IN MY REF
Hi
same thing happened to me with a westinghouse upside down fridge freezer yesterday. i talked to a mate of mine who is a refrigeration mechanic and he said to check the air flow going into the fridge via the freezer and to see if the fan above the evaporator was working. he also said you would probably have to have the fridge light switch depressed as the fan is designed to only run when the fridge door is closed. when i removed the cover in the back of the freezer to inspect the fan i found the fan was spinning okay, but my evaporator was choked up with ice. i gave it a good defrost and clean out and everything seems okay now. i think the heating element around the evaporator (frost free) is not working and that is why it has iced up. apparently it is very important to have good airflow in and around the evaporator so if it is iced up or you have too much stuff in your freezer it will not be efficient and your refrigerator performance will suffer.
to have a rough idea on whether you have enough gas in your system, he suggested feeling the pipes coming out of the compressor. in normal conditions one should be quite hot to touch and the other should be a little bit cooler than room temperature. your condensor (which is the big coil up the back of the fridge should be warm and your evaporator (coil behind a cover in your freezer should be cold to touch)
hope this helped
john
Posted on Jul 16, 2008
Refridgrator's compressor run for few seconds and stop. No cooling
That is called short cycling and caused by a defective start relay, overload, run capacitor, defective fan motor or defective compressor and of course it needs to be diagnosed to have the fridge cooling again
APPLIANCE 911
Dec 03, 2015 | Refrigerators
Gmc safari air conditioning compressor does not engage.
Have the system checked for a leaking compressor, it sounds like you have lost the charge of refridgrent.
Jul 16, 2013 | Cars & Trucks
Ac won t start in my 94 sl
Does it have a full charge of refridgrent?
Jul 06, 2013 | Cars & Trucks
Vehicl AC Warm
Has the refridgrant charge been checked?
Jul 01, 2013 | 2005 GMC Envoy
Sides of Toshiba fridge very hot and between freezer & refridgrator very hot. Fridge was in storage for 3 months
It sounds like you feel the heat from the condensor built into the cab. to prevent sweating, let it run and see what happens.
Feb 20, 2011 | Refrigerators
Water on the bottom floor of the refridgrator..inside.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Refrigerators
Ice build up around fan in frezeer.makes looud noise....if not melted the refridgrator part a bottom of unit stops cooling.....if melted fan runs smthly....things cool well, but happens again over noght...
The defrost circuit has failed. Typical failures are the defrost heater has opened, the defrost timer if equiped, is not advancing or the defrost thermostat is open. To check the heater, melt the ice, and use a meter to check if the heating elements are open, if they are, then you will need to replace the heating element.
Aug 23, 2010 | Kenmore 64802 Top Freezer Refrigerator
My refridgrator does not get cold the panel says the filter needs to be changed the only thing im finding is the water filter could that stop the refrigrator side not to get cold?
It has nothing to do with the water filter...
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 16, 2010 | KitchenAid Superba KSCS23IN Side by Side...
Ac problem. It wont come on.
is the AC system charged? a low charge (due to a refridgrent leak) will keep the AC from working.
Jan 17, 2010 | 2006 Hyundai Sonata
1998 dodge durango slt compressor keeps on turning off and on
THE IS CAUSED BY THE SYSTEM BEING LOW ON REFRIDGRENT, THIS IS CAUSED BY A LEAK, MOST COMMON CAUSE OF THE LEAK IS THE FRONT SEAL OF THE AC COMPRESSOR.
Jul 24, 2009 | 1998 Dodge Durango
Refrigerators Logo
220 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
