Question about Linksys Wireless-G WRT54G Router
Linksys wireless g wrt54g router setup
Iam installing my router for the second time after it got messed up, so i get to the point where you have to make password then it checks the internet connection and it said cant find internet please turn off/on the modem so i did and i kept doing that for an hour and half and it still cant get internet. i have tried 3 differnet ethernet cables and that didnt work and all the lights on the front panel light up and its worked before. what could be the probelm?. the mess up was it stopped wireleslly giving my ps3 internet and my computer internet so i uninstalled an tried to isntall again and it gets to the part where you have to make your own password and it checks for internet connection and it says it can find anything. iam trying to set up wireless internet for my ps3 and have internet runnig to my pc what could be the porbelem? my router and internet modem are right above my pc
  • Anonymous Jul 16, 2008
    can't get my wireless remote to work
    talked to a rep but was not helpful
    Scholar:
  • 61 Answers
I would check the ip addresses for the modem & the router.You can do this by typing a command line from the "Run" entry on the Start menu. At the command line type in ipconfig /all & there you will find the ip addresses. My hunch is that they are both set to 192.168.1.1 - you will need to change one of these to something like 192.168.2.1.
Posted on Mar 24, 2009
Try not entering any password. Is the password for the router access, internet access, or wireless access. If you do not enter one it will not require one later. Use that to get it going then you can always go back and add a password later
Posted on Jul 16, 2008
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
I messed up my login passwords how can I reset?
I think you should try to reset the router to factory default settings and reconfigure it manually.
Press and hold the reset button on the router for 30 seconds. Release the reset button and wait for 30 seconds. Power cycle the router and reconfigure it manually.
See how to reset Linksys router
See Linksys router setup
Jan 16, 2012 | Linksys Wireless-G WRT54G Router
How to setup linksys router
You can setup Linksys router without installation CD or software.
Connect the computer to the router and open the setup page of the router.
Change the Internet and wireless settings manually.
I will suggest you a website on How to setup Linksys wireless router.
This website may help you installing your router
May 28, 2010 | Linksys Wireless-G Broadband Router
I want to install HG510 provied by mtnl
You have to take a pen and hit the reset button, and hold in on it for about thirty seconds to minute. Be sure to re-secure your wireless internet after that, so your neighbors can't use it, by using a personal password. It is located under basic wireless setup on the router page. 192.168.1.100 is the default after the reset of linksys been pressed.
Apr 06, 2009 | Linksys Wireless-G WRT54G Router
I am trying to hook up a omni antenna to a wrt54g is it possible in a motel setting
Hi there If u have a linksys wrt54g router. the omni antena will not give u the maximum wireless signal if u are going to set it on a motel, u need to setup a wireless access point in order to broadcast the signal or to repeat the signal u need a wireless access point and the model # is WAP54G..
here is the link just incase u want to know more about on how to set up a wireless access point
1. How do I configure an access point as a wireless bridge?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4194
2. How do I configure an access point as a wireless repeater?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4200
3. How do I configure an access point as an access point client?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4202
4. How will I know if an Access Point is configured as an Access Point?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4165..
check this out and i hope this will solve ur concern..
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Need to redo wireless setup betw linksys & westell
You will need to assign a different ip address to the Westell modem - I am assuming that both the router & modem are using the same ip address 192.168.1.1? If that is the case, then assign 192.168.1.2 to the modem.
Mar 15, 2009 | Linksys Wireless-G WRT54G Router
Connecting 2 wireless routers
As a wi-fi technician, it is not recommended to extend the wireless signal using another wireless router. Having 2 wireless routers will just cause conflict to your wireless network. If you still have time, please replace the router with a Wireless Access Point (WAP54G). WAP is easy to setup. Just plug it to one of the ethernet port on the back of your router and run the setup CD that came with it, that's it. It'll extend your signal.
If your main concern is just extending your wireless signal to another far place outside your house, Wireless Range Expander (WRE54G) can also be used. It is a similar device like an Access Point but its signal extending capability is more powerful than Access Point. Its also easy to setup, just the setup CD that came with it.
You can also contact the Linksys toll free tech support # at 1800-3267114 if you wanna resolve the issue over the phone. Hope that helps.
-Regards
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
Installation linksys wireless-g router
In order for you to setup the WRt54G to work with your Ibook you nee d to manually configure it since the setup CD for the WRt54G wont run on your MAC computer, In manually configuring the router you need to access the setup page of it and there you can set it up, I will advice you to contact Linksys tech support so one of their tech can walk you through with the process the number 800-3267114 they are open 24/7...
Hope that helps...........
Oct 10, 2008 | Linksys Wireless-G Broadband Router
My laptop won't work wireless
Use windows network setup wizard to help in setting up your wireless. The wizard can search for your wireless. Some people believe you gan get away without using Linksys's software & I agree to a point. However Linksys believes to maintain a good connection you should install the software for the wireless router. You can download it from the link below. Check out the link "Learning Center". You might find it helpful. http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
I suggest to all running a wireless connection to set up security with a password to keep freeloaders from tapping into your bandwith for free.
Luck!
Please vote...
Jan 23, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
145 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
