Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Fridge and freezer not cold
My fridge and freezer is not cold.  The light is working, but the ice machine, freezer and fridge portion is not cold.  I just found out.  Is there something I can do or do i have to call someone to fix it?
  • 3 more comments
  • Ruedico Jul 28, 2008
    I have the same problem. Did you find a solution?
  • finton Sep 03, 2008
    My light works on the inside but the fan and motor does not come on.
  • prashanth22 Sep 06, 2008
    Same is my case. Light is working. It is not cool enough. Two of the four vents is providing cool air. The other two vents are blocked. What do I need to do?
  • mjlowers Sep 08, 2008
    cleaned out the bottom vents with a shop vac
  • hagendelores Sep 08, 2008
    The refrigerator suddenly stopped working.Neither the top or bottom was cold. We tripped the breakers on the outlet box but it didn't help. we left it plugged in and about 10 hrs later it turned back on by itself and is starting to get cool again. Is that the thermostat or maybe it's haunted?
    Scholar:
  • 97 Answers
Hiya
sounds like there's a thermostat problem.
hope this helps
please dont froget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Freezer on bottom, cold, fridge not cold,ice on
Probably the difusser door that allows cold air from the freezer into the fridge portion, either stuck or control dial faulty
Aug 22, 2009 | Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer icing up fridge not cold motor not continualy running
You have a problem in the defrost circuit, most likely the defrost heater or timer, there is also often a thermal limiting device that prevents the heater from going into nuclear meltdown incase it ever gets stuck in an on position.
Most residential refrigerators only actually cool the freezer portion. There is an air door and fan that takes the cold air from the freezer and pushes it into the refrigerator portion. When the defrost heater stops working ice will build up in the freezer, this then blocks the flow of air into the refrigerator and the problem you indicated is the result.
Mar 11, 2009 | Refrigerators
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
125 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
