Question about Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator
Owner manual for Amana model ABB1924DEQ
My refrigerator is not cold, the freezer is fine. I've upped the temperature and it still feels the same - not too cold. It's only 3 years old. Anything I can do before I have to call someone?
I can't find my owners manual. Is there someplace I can download it?
Thank you inadvance for your help.
Kindest regards,
Jodee Cizek
Email: Jod57@aol.com
5 Suggested Answers
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
fridgetech
  • 473 Answers
SOURCE: Temperature Problem - Amana (Maytag) Refrigerator Model AFD2535DES
This comes with a 1 yr warranty from date of purchase.  Look and see if there is a thick frost buildup on the back panel in the freezer section.  If no frost, shut the freezer door and feel for air flow out of the top middle vent in the fridge section.  I would remove that vent cover to make sure the damper is open.  If the damper is closed push it open then feel for air flow.  If no air flow is detected then the evaporator fan motor is bad which is a very commom problem on this model, in fact the most common problem.  If the damper is shut and when you hold it open you do feel air flow then the damper is bad.  Let me know what you find.
Posted on Oct 14, 2007
the dr
  • 447 Answers
SOURCE: amana refrigerator
Sounds like it has either a bad compressor relay or if the brand name of the compressor is Tecumseh, it will need to be retrofit to a more reliable longer lasting Embraco compressor.
Posted on Jan 10, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 1214 Answers
SOURCE: anama bottom freezer
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 16, 2009
Where is the defrost timer / does my fridge even have one?
Most often the defrost thermostat fails there should be a diagram or small manual hidden under the kick panel or taped on the back of the refrigerator. I believe this model uses a computer to control all functions including defrost . There should be a way to run diagnostics on this to tell you your problem if you can find the hidden manual.
Aug 06, 2014 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Refridgerator section is warm, freezer is cold, however the freezer has alot of frost build up? is it ready for the land fill?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Top portion of frig is warm, bottom area seems cool. Freezer below is cold.
heatman101
Apr 26, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Temperature inside refridgerator is not very cold even at higher cold settings??
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 24, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Refrigerator is not cold, but it is definitely getting power. It is an amana model abb1924deq
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Feb 06, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
My amana refrigerator abb1924dew is making a sound like it the motor wants to rev up but it goes back down. In addition while this is happenning, the electrical panel which reflects the setting blinks...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Nov 02, 2010 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Amana BR22 top refrig not cooling
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
May 24, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
No Temperature in Refrig
It indicates that there is problem with your thermostat .
How old is your refrigerator ?
Are you facing this problem frequently ?
SAM ANDERSON
Sep 30, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator Logo
228 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
