2 problems with speed queen washing machine
Can anyone help with troubleshooting washing machine problem?
1 - I took the front panel off to troubleshoot a leaking washing machine and...now after I put the panel on it won't start. It just hums...
2 - Washer is leaking and I am attempting to fix, any advice?
  • JONA777X Jan 03, 2009
    HI . I HAVE A SPEED QUEEN , AND THE MACHINE WONT STARTED , I CHANGE THE FUSE AND IT WILL STAR , BUT , THE FUSE HOLD JUST ONE LOAD OF CLOTHING , AND THEM I HAVE TO CHANGE THE FUSE AGAIN BECAUSE IT BURN AGAIN , SO I HAVE TO CHANGE THE FUSE AVERY TIME THAT I HAVE TO DO LAUNDRY , PLEASE HELP MEEEEEEEEEEEEE
    THANK YOU
    Novelist:
  • 177 Answers
The motor is not starting this is the humming noise not a good sound, try it in spin to see if the motor runs in this direction. You may have a motor issue because of the water leaking on the motor?
Now that you have the front panel removed you can look for leaks, you will need a flash lite, start a cycle on the small setting and look for where the water is coming from. If it is coming from the center of the tub above an aluminum case which is the transmission you need a tub seal, if the water is coming from somewhere else it could be a pump, or hose, or ?
Posted on Jul 16, 2008
I had my speed queen about ten years it washes properly when it come to spin it go very slow and with jurking movements what can be wrong please
Open up the front panel by unscrewing the three screws at the bottom of the panel and lifting the panel up and out. Please disconnect the electrical power supply first. Look inside the machine for the van belt between the electric motor and the big pulley underneath the drum. Check the condition of this belt as it might need to be replaced. ( badly worn over all, inner rubber area cracked badly, rough sides ect). TAKE NOTE: Replace with genuine Speed Queen part as a normal vehicle v-belt will not work. Pressing against the belt will be a small pulley attached to a swing arm under tension of a spring. Slight shortening of the spring might help but only as last resort.
Aug 12, 2014 | Speed Queen Washing Machines
I have a top loading Speed Queen. The drive belt broke and I need to replace it. How do I remove the outer metal cover to get to the working parts
there are 2 5/16 screws located at the bottom of the front panel. Remove the screws and pull the front panel away from the machine on the bottom.
Dec 19, 2010 | Speed Queen AWS44NW Top Load Washer
Speed Queen CTSAOAWN front loader, makes quite a bit or noise (more than it used to ) when in spin cycle -- rattling, scraping sounds. I'd like to open the front of the unit to see if any suspension...
take front lower panel off.. there will be a white filter housing facing you unscrew abs /plastic clean out usually pennys /dimes quarters put back the same way you took off bingo problem solved<!-- from fixya rte -->
Jul 27, 2010 | Speed Queen CTSA0AWN Front Load Washer
I am looking for a model number on a Speed Queen Marathon washer
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
Mar 06, 2009 | Washing Machines
Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Dec 21, 2008 | Speed Queen AWS75NW Top Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
350 people viewed this question
Top Washing Machines Experts
