Question about ViewSonic VX2000 (Silver, Black) Monitor
Vx2000 I have a viewsonic vx2000 monitor and works fine for about 20-30 min. After that, the monitor goes completely either white or green. When i move my mouse I can see a vertical line move where my arrow would be. All I have to do is turn it off then immediately back on and it works fine for another 10 min or so. Any suggestions?!?! thanks in advance
    Scholar:
  • 101 Answers
This is most likely a problem of bad electrolytic capacitors. New capacitors must be soldered in. Visit http://badcaps.net/ for more information. Before doing any of that though, check if it is still under warranty. Here is viewsonic's warranty information. http://www.viewsonic.com/support/warranty.htm
Posted on Jul 15, 2008
VS10162 back screen
The reason I ask you to hook up the viewsonic directly to the PC is to find out if the problem is in the USB adapter or in the monitor itself, you can also try your Viewsonic with other computer.
Basically just have the PC, VIEWSONIC, NO USB or the monitor. We need to narrow down the problem.
May 12, 2010 | ViewSonic VX922 19" Monitor Flat Panel
I have a Viewsonic VX2245wm or VS11349, Works and then it goes black for 2 to 4 sec then runs for 10 to 15 min and goes black
Look at the power supply section for bad caps first, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside, it can also be caused by bad inverter circuits or bad lamps.
Feb 20, 2010 | ViewSonic VX2245WM LCD Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
Screen goes white after 12 seconds
Per the first hit on Google for 'viewsonic fades white', http://forums.worldofwarcraft.com/thread.html;jsessionid=A68BB7FE4AF6EC93EB730E8588C865A2?topicId=4064461903&sid=1
(which you should go on and read in another tab,) you need to contact Viewsonic about an inverter board (for the CCFL backlight) or switching your backlight to LED while spoofing the INVERTER_OK signal to keep the display from giving up as it does.
So...this should be a hint that you should respect others' time (or be moved to increase usability) better by searching for cures in similar Viewsonic monitors, and of course checking the obvious search terms.  Viewsonic evidently has a nifty knowledge base available for all on the web, so that one would be a nifty surprise.
Aug 18, 2008 | ViewSonic VX1945WM LCD Monitor
Power dies when video signal applied
I fixed this problem by replacing all the electrolytics 1000uF and 1500uF on the power supply/inverter board. All were either bulging or had burst at the bottom rubber seal. This cleared up all problems and I am using this monitor successfully at this very moment.
Jul 14, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
VX2000
I would say power supply or power save problem check in menu to see if there is a powersave adjustment if not I say powersupply
Jan 16, 2008 | ViewSonic VX2000 (Silver, Black) Monitor
ViewSonic VA912b (Back light with blank dark screen)!
the capacitors in the monitor give out have to see a technician
Aug 19, 2007 | ViewSonic VX910 19" LCD Monitor
Monitor Blanking
Buy a new monitor... It will make your eyes stop watering.
Sep 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
ViewSonic VX2000 (Silver, Black) Monitor Logo
174 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
