I keep getting these different codes on the panal and the machine just stops in the middle of the wash.....What do I do.
  • 57 Answers
CHECK YOUR WATER PRESSURE
Posted on Jul 16, 2008
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
I have a 300 Series Bosch front load washing machine witn an E:27 error message. I can't get it to reset. What is wrong?
Do you know what the E:27 error code means? Different machines have different codes. I am not a bosch expert, but if you provide the complete model # to your machine chances are good that i can find the meaning of that error code and maybe a whole lot more.
Jan 06, 2013 | Bosch Washing Machines
During spin cycle the washer allows water to enter the machine. If I shut the water during this cycle it spins out fine but when the cycle reaches the off position it doesn't really shut off. Sounds like...
open the door on the washer,in the middle rear just above the tub you will see the shute were the water comes in to the washer,make sure it is connected to the back panal,if is not than you will nead to remove the washer top door and cover assemble,there is a panal between the dryer and the washer,at the top of the panal on each side you will see a screw,remove them and remove the panal,at the back of the cover on each side you will see a clip with a 5/16 screw in it,remove the screws and slide the cover forward about 1 ",next lift the frount of the cover and on the right side you will see the door switch conneter,unhook the conneter and remove the cover,next you can see the water inlet shute,if is broken than replace it and hook it up to the back panal,next replace cover and panal and run a test run.
Jan 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
At the middle of my load there was stop with code symbol E3
E3 is that the machine can't see that the motor is spinning. Could either be a loose connector at the motor or a loose hall-effect sensor. this might be a fairly easy fix for a repair tech,
Dec 27, 2009 | Maytag MAH8700A Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Machine off balace during washing then stopped working
could be either interface control(pushbuttons and knob) or machine control (gray plastic box)
Jun 01, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Error E90
That happened to mine, and apparently it is the connection to the control panal at the front of the machine or the desplay unit (4 blue wires). Take the top off and wiggle them around or re-connect if any are loose. Mine worked for one wash and then started displaying E10........so i'm not amused and I think i may end up getting a hotpoint!
Nov 09, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
