Question about Kenmore 4292x Front Load Washer
Low Water Level - Kenmore Elite HE3t - 42932
I've owned the washer and dryer pair for about 6 years. Not real happy with the quality of the products, and certainly not happy with Sears Service. I'm wanting to know if there is a test to know if the tub is filling with enough water? I feel as if the water level isn't high enough, for some reason. In the past, I've called Sears Service and they just start replacing parts until they think they have fixed it (thank goodness for extended warranty), but now, my homeowner's warranty is footing the bill, and their guys don't seem to know the product very well. I'm hoping there is a test, or someone that would know how high in an empty tub should the water level be? Thank you for your time.
  • Anonymous Nov 20, 2008
    I have a level problem with a kenmore washer and lines are good but water level changed from high to medium level. not sure why or what to check for this repair.
I would like to know the same thing. How high should the water level be in an HE5t? The serviceman didn't seem to know.
Posted on Dec 02, 2009
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Nov 22, 2017 | Kenmore HE3T Washer
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Aug 01, 2011 | Kenmore Elite HE5t Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Got a Kenmore Elite HE3t Front Load washer from my old man, hasn't been used in 5 years... sat in my basement for the first month i lived here unhooked and unused... FINALLY, got a dryer, hook everything...
A burst hose or a broken hose connector clamp most likely. Open the back after disconnecting power. Use bright flashlightto see where its dripping from and confirm the hose-clamp is brokem/ open or a connecting hose is burst. Carry broken hose to hardware store like Rona for a replacement tubing, cut to size and re-instal, voila!
Dec 13, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite he3t steam front loader - 110.4674-2 --- f35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
Not a problem ... Just bought a Kenmore Elite HE3t washer & dryer and read bad evals on these good machines, or should I change my order?
I would send it back ASAP, had our Kenmore Elite front loaders for less than 2 years and it has been nothing but trouble, so far it has cost us $200.00 in repair fees and washer still not fixed, expecting another so called Sears expert out tomorrow that will be another $129.00 for just showing up without guaranteeing he will fix anything.i
Sep 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washing machine spin cycle slow. The clothes are still dripping wet when removed from the washer.
In my HE3T, this was indicative of the water pump going out. In its 8th year, my HE3T is now on its 3rd water pump.
Aug 02, 2009 | Kenmore Washing Machines
I am thinking about buying a 2003 kenmore elite washer and dryer for $500. they are a HE3t. are there any problems I should be aware of with this year and model.
No unusual problems. Keep it maintained properly - and you have a great washer.
Jul 15, 2009 | Kenmore Elite 45986 Front Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 4292x Front Load Washer Logo
571 people viewed this question
Sal De
 Brian Main
Brian Main
