Question about Samsung P10 C XTC 1900 Notebook
  • Anonymous Jan 05, 2009
    I am suffering the same problem!!!
  • 108 Answers
Your DVD drive need replacement you can buy one online at ebay stores
Posted on Aug 23, 2009
I can not get cd
If the drive does not spin when you close it then the motor has failed.
If the drive spins, but the disc won't play then the laser on the drive has failed.
In both circumstances you should look into a replacement part for the laptop.
Sep 06, 2011 | Computers & Internet
Hi, I have a plenty of region 3 DVDs that I would like to play with my region2 PS3. Can you help pls
  1. Take the DVD from another region that you want to play on your PS3 and put it in your computer's DVD-RW drive.
  2. 2 Open DVD-copying software you have on your computer. Examples would include DVDXCopy Platinum and Nero Burning Rom. Anything that can make a straight copy of a DVD will do.
  3. 3 Use the DVD-copier software to make a copy of your DVD. Both Nero and DVDXCopy Platinum will make direct copies of commercial DVDs, so they'll both work well for these purposes. Making a copy will remove any region coding the disc has and effectively make it "Region 0," or "all-region." As long as you own the DVD you are copying, you are doing nothing illegal.
  4. 4 Put the copied DVD in the PlayStation 3's disc tray. Despite originally being from another region of the world, it will now play perfectly in your PlayStation 3.
Jan 23, 2011 | Video Game Consoles & Games
My dvd rom doesn't read cds.when i put one in it just makes funny noises, spins for a while, and stops. what's wrong with it??
Sounds like your DVD/CD rom has failed. Take your PC to an shop for a replacement/install.
Nov 21, 2009 | Computers & Internet
Disc won't play on computer
Make sure the disc is DVD/or just a CD if its a DVD make sure you have a DVD-ROM/ on older comouter now they cannot play DVD disk verify that your format is correct, Thank you
Apr 29, 2009 | Computers & Internet
Blu-ray disc stops at main menu
Has your husband verified you have the most current Firmware for your unit? this should take care of your issue
Jan 22, 2009 | Samsung BD-P1500 Blu-Ray Player
Video copied to disk but cannot view on PC or other DVD players.
This is the unfortunate thing with copying DVD's. Unfortunately when a DVD is copied only certail players will play it back. I can burn a disk on my laptop and it will play fine in the laptop and on my Sony DVD player, but my Samsung will not read it. This is why when you burn DVD's it's important to find a brand that is read by numerous DVD players. Try using the Sony disks.
Hope this helps.
Nov 12, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Samsung P10 C XTC 1900 Notebook Logo
64 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
