SOURCE: Will the Pioneer 50 W
i relly have no idea i got a place u can call that will be able to anser u q and a. his number is 1440-888-1121 ask for jake he'll be able to help u out let me no how it works out
SOURCE: setting clock radio
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control. Check which control lets the selector jump from "hou" to "minute and set the minutes. To exit setting menu, depress "clock" button again
SOURCE: How do I set the clock and preset radio stations on a Pioneer fhp800bt Premier?
Usually, you need to have key on and radio off. press and hold function button till u see settings menu. Set radio stations by press and hold preset # while on station till beep or display blinks.
SOURCE: I would like to know how to set the clock for a
Here's a link to the manual at Pioneer's web
site.
Here's how you set the time (from page 16 in the manual):
1:
press SOURCE and hold until the unit turns off.
2: Press AUDIO
repeatedly until the clock appears in the display
3: Press (left
arrow) or (right arrow) to select the segment of the clock display you
wish to set (hours, minutes)
4: Press (up arrow) or (down arrow) to
set the clock.
- To cancel clock settings, press BAND
- to
save clock settings press AUDIO until the display stops blinking
If this helps, please hit the "thumbs up" for me!
SOURCE: I have lost the radio
Are you sure it needs a code? I have never seen a Pioneer that is code protected.
