Power Source/Supply My 150 Watt Micro ATX just burned up again. What comparable power supply/source can I use with this computer?
    Habit-Forming:
  • 115 Answers
Confirm the wattage(how many watts e.g 150W) needed by your system from your manual.Make sure the wattage of power supply you are buying exceeds it or is equal.
Posted on Jul 16, 2008
I have corei3 system. their confiuratio is intel corei3 processor 3.2 ghz/intel DH61ww motherboard,seagate 500gb sata hdd,lg 22x sata dvdrw50w smps,atx comuter case,15.6" lcd acer monitor,xerox phesar...
sounds like you need a higher wattage power supply!! meaning if you have a 500 watt power supply and it burned up then you may need a higher wattage power supply!! try a 650 or 750 watt power supply. there is only 4 screws holding the power supply in place, just un-plug all internal power cables and remove the screws and do the reverse with a new power supply. please go slow the connecting internal power cables are keyed meaning that they only fit one way!!! DO NOT FORCE THE PLUGS INTO THEIR SOCKETS OR YOU WILL BLOW UP YOUR MOTHERBOARD!!! sorry for the caps!
Aug 24, 2011 | Intel Desktop Board DH61WW Classic Series...
THE COMPUTER WILL NOT POWER UP AND THE FAN ON THE POWER SUPPLY IS NOT RUNNING. THE LED ON THE BACK OF THE POWER SUPPLY IS ON WHEN POWER IS APPLIED. DOES THE FACT THAT THE FAN IS NOT TURNING ON MEAN THAT IT...
It could be a software glitch that is preventing your motherboard from powering up: try to unplug the main power cord from the main AC source for about 5 minutes, replug and power Desktop again and see if it is back to normal.
Good luck! Hope it works for you!
May 15, 2011 | Hi-Pro Hipro 200W ATX Power Supply p/n...
Where can I find power supply for HP model ATX300-12ZBD
There are lots of ATX power supplies on the market. You do not need to use a HP 300 watt power supply. Just purchase one that suit your requirements - 300 watt or more. These power supplies have standard mounting holes.
Mar 10, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
I am having a problem getting a power unit for my HP Pavilion. The part number I need is 0950-4107. Would another part numbre suit instead, if I am unable to get this? Thank you.
I believe that you mean you need an internal uATX (micro ATX) supply.
Whether it's a Micro-ATX or ATX supply, 12V or not, your PC could do with a quality one anyways. Unless you work for HP, in which case I don't know why you'd be on here, I recommend going to http://newegg.com/ (or your preference) and simply finding an equivalently or better rated supply.
Some sites do have proprietary supplies for sale. Can't think of any off the top of my head. Dells are common, HP models can't be too hard to find.
Aug 13, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
The PSU bestec atx-250-12e is dead, there is an easy fix for it
You can find the same psu at ebay with free shipping.
http://itemlistings.ebay.com/sdcsrp?fl=360131455504&product=bestec+atx-250-12e&sconstraints=PriceMin.Value%3D23.00%26PriceMax.Value%3D45.59
Aug 20, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
ATX-300GU PSU: 32V around Q4/Q5 circuit
could just be the regulating power transistors are burned out or one of their biosing components, there a few meaty capacitors that may be causing a surge, but the safe thing to do would be to start with a new one, the reason is, modern drives are so sensitive that you could blow their circuitry and then lose the harddisk! All the best - the Yeti
May 17, 2009 | AOpen Power Supply: ATX-300GU (PS4300GU)...
Upgrade for Bestec ATX-1956D (HP p/n: 0950-4106)
How about the LC Power LC350M Micro ATX - 380 Watt
or the
Logisys 350W Micro ATX
They should fit your form factor and output as much as 350W being relatively cheap, but neither gets 18 amps on 12V rail...
I think no power supply of that size has an output like that...think about a cheap but substancial chassis upgrade if you need that power...Have a look at directron for the PSUs.
Feb 13, 2009 | HP Bestec ATX-1956D 200w HP Part No...
Updateing power supply
You will have to figure out if your current case is ATX or Micro-ATX. Afterward find a power-supply online that will fit an ATX or Micro-ATX case. Another factor to consider is your motherboard's power connector. Some motherboards can only take a 20 pin while others take a 24 pin.
Perhaps a good power supply choice would be a PSU that has a 20+4 pin motherboard connector.
You can find some good Power Supplies online here. Just use the navigation menu at the top and go to: Computer Hardware>Power Supplies. After select, "Power Supplies" on the left and you will be able to find PSUs for desktop computers. I recommend the PC Power & Cooling brand, they are extremely reliable. Some of their PSUs also offer the 20+4 pin connectors.
Remember, it must fit your case and must fit your motherboard! Have a great evening.
Feb 04, 2009 | HP (152769-001) (152769001) 250-Watt Power...
Power Supply
The power supply should be FSP200-60SPV-D - 200 Watt ATX Power Supply, its the common replacement power supply for HP, Compaq. You go to a store and ask for the FSP200-60SPV-D - 200 Watt ATX Power Supply, its the one you need
May 30, 2008 | Computers & Internet
Computers & Internet Logo
71 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
