Question about ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/ VGA/ AUdio/ LAN/ MATX (GXMBP4P800VM) Motherboard
P4P800 SE vs P4P800 Mx
I have the P4P800 SE and I work ok, but I have a 2.4 chip out of a P4P800 MX board. Is it safe to change (upgrade) chips without harming the system. And will I need to make any changes......Help please
  • Anonymous Mar 21, 2014
    yhow to install power
    Novelist:
  • 150 Answers
The general answer is yes.
1) Both of these boards have the same CPU socket:
"Intel Socket 478", so they are CPU compatible
at the pin level.
The different support chip-sets (North and South bridge)
do provide different I/O features and bus optimizations,
but this is NOT a problem to the CPU, nor an issue to
worry about.
2) Also, both these boards are smart enough
in the BIOS, to automatically detect the CPU
and to automatically set the clock speeds and
power supply voltages.
The P4P800 board is more then fast enough to take full
advantage of the 2.4 GHz CPU.
The only time you could get into trouble is if you
override the BIOS settings to over-clock or over-voltage
the CPU or memory, without knowing what you are doing.
3) If you are not sure, just let the BIOS do its thing, and auto
set the CPU and memory settings.
However ! ...
4) Be extremely careful when physically swapping the CPU's
and heat sinks:
a) Make sure the computer is physically unplugged,
and the power has been off for a few minutes.
b) Unclip the whole fan/heat-sink assembly as a unit if
you can, and wash the bottom of the heat-sink with
rubbing alcohol to remove the "white gunk"
(heat-sink transfer compound)
Similarly clean off the CPU's after you remove them from
the socket, do NOT drip alcohol onto the mother-board,
because it could dissolve, soften or contaminate it.
The alcohol will NOT hurt the metal heat-sink, nor the
ceramic top of the CPU.
c) To remove the CPU from the socket (and to replace it)
release the socket lever on the socket FIRST.
The CPU should slide in and out of the socket without
ANY force what so ever, and make sure that PIN-1
and the shamfered corner are oriented correctly !!!
If you plug in the CPU the wrong way, and power it up,
it is GAME OVER !!!
d) Take extreme care not to STATIC zap the mother board,
or the CPU. Wrap a thin bare wire around your wrist,
and connect the other end to the computer case,
before handling ANY electronic parts.
(With the computer still turned off and unplugged :)
This is EXTREMELY important, because your body
can accumulate a very small charge at a very high
voltage of several thousand volts before you even feel
a tingle, and when discharged can fry or injure every
chip on the board.
do NOT remove the mother board from the box just
to change the chip, if you can possibly avoid it.
Handling motherboards is ALWAYS risky due to
the risk of static as well as flexing the board and
braking internal "plate-through-hole" connections.
I am an expert many times over so please take my
word for it.
5) After you install the new CPU in its socket, but BEFORE
you re-attach the heat-sink, you need to apply a liberal
amount of NEW white heat-sink compound between the
heat sink and the CPU.
This white goo is a silicon based grease that drastically
improves the heat transfer from CPU to heat sink, i.e.
lowers the thermal resistance in degrees per Watt,
to keep the CPU from overheating.
Many people skip this important step, but if your CPU
overheats, it won;t last long.
The heat-sink compound is available from any electronic
or computer shop.
6) Make sure that you clean and reconnect the CPU fan,
and check that it is working properly.
7) Make sure that your power supply is strong enough to
provide the additional current required by a faster CPU.
Keep in mind, that the amount of power consumed, and
heat generated by the CPU is directly proportional to
frequency and to the square of the operating voltage.
Also, faster CPU's never last as long as slower ones,
due to increased nano-scale current densities and
atomic scale erosion due to these currents. Although
the currents are miniscule from our point of view, so are
the circuit geometries, and if you do the math, (I have)
the effect of sending some of these internal currents
through the nanometer-sized conductors is like forcing
the Mississippi river through a half inch pipe.
The sheer momentum of the electrons is sufficient to
knock whole atoms out place and slowly erode the
tiny semiconductor structures.
All chips WILL fail in time. The faster they run the sooner
they fail, but hopefully "after" they become obsolete.
8) So make sure you have enough fans to keep things cool.
9) Finally it is good to identify your speed bottle necks,
before you start changing things, for example:
If the RAM is marginal, it will not run reliably at the
increased bus speeds. The mother board (BIOS)
compensates for this when calculating the timing
settings, and increases the number of bus-cycle wait
states. The net result is that your faster CPU can result,
in a slower computer under some conditions.
Another thing people tend to ignore is the amount of RAM.
RAM is 10,000,000x faster then hard disk.
When a computer (Windows) starts running out of RAM,
it begins to swap less used data to hard disk, in a process
called virtual memory paging. If it pages too much, it is
called thrashing. A thrashing computer can take hours or
even days to perform a task that should only take a few
seconds.
Increasing the speed of the CPU by 20% often doubles the
cost. The same amount of money is put to better use
increasing the amount (and quality) of RAM, with much
more impressive results.
For a Pentium-4 based XP machine I recommend 2 Gigs
of RAM, only because 32-bit Windows can only access
4-Gigs, 2 of which are reserved for the OS and remapping
the video card. This leaves 2 Gigs for user app's.
IT is possible to configure windows to use a little more, by
setting the /3GB or the /uservalu= switch within the boot.ini
file but this can lead to unforeseen complications.
The problem with 64-bit windows is that it still has limited,
driver support and you need a 64-bit motherboart/CPU
such as a core-2-duo.
Good luck, please rate my answers.
Martin
Posted on Jul 16, 2008
Xcv
Posted on Nov 04, 2008
  • 304 Answers
As long as the front side bus speed is the same all will be fine, simply plug and go my friend..... I've done this myself on 100's of systems. Make sure to use new heatsink compound between the processor and the heat sink though.
Hope this was helpful,
George
I have a P4P800-MX motherboard on my system ,I previously replaced the cpu as it was getting too hot, though now the board is still running hot ,would this mean the board is damaged and should I replace...
its not the board that is the problem it is the ventilation and the way in which the computer is cooled you should not replace the board because no matter the condition of the board it has nothing to do with the temp you should repalce the fans or the heat sinks!
Dec 23, 2009 | Intel ASUS X Series Motherboard P4P800-MX...
Audio driver
when you go to asus site search for motherboard number not audio driver. all drivers for chips made to motherboard should be in a package
Aug 20, 2009 | ASUS M2N-MX Motherboard
I can't work out what size chip to put on my motherboard
Asus list supported CPU's for your P5S-MX SE Mb.
Click on the link below;
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S-MX%20SE&product=1&os=17
The further down you go the stronger the CPU.
When looking for the CPU that you want, you'll also need the bios version listed across from that CPU.
The next link will list everything pertaining to your Asus board.
Look to the left for more information like FAQ, supported CPU & Forms.
(For the link below to fulley open, you'll need to choose your operating system from the drop down menu & click Search in order for the driver link to load);
http://support.asus.com/download/download.aspx?modelname=P5S-MX%20SE&SLanguage=en-us
Use the manual to help you. (Download it needed).
BIOS 0306 is the latest revision & supports the newer CPU's.
Pentium Dual Core E2220(2.4GHz,800FSB,L2 1MB,M0).
Link to some CPU's;
http://www.google.com/products?hl=en&ei=oZEIStOIMpuWMdmEmcwE&resnum=0&q=Buy+Pentium+Dual+Core+E2220(2.4GHz,800+FSB,L2+1MB,M0)&um=1&ie=UTF-8&ei=qJEISshJj7402Mno2AI&sa=X&oi=product_result_group&resnum=4&ct=title
Cheers!
Mike
May 11, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
I carnt work out what size chip to put on the p5s-mx se Socket LGA775 motherboard
Ok no problem I can help you there. First you want Intel or AMD. I would take Intel. Then you want Core Duo or Core 2 Duo, I'd take Intel Core 2 Duo, then you need to find out the Frontside Bus Speed of your motherboard, it has to match the CPU. So let's say its 1,066MHz. And you want something faster than 1.8 so go with 2.4GHz. So now we looking for a Intel Core 2 Duo, 2.4GHz, 1066MHz bus speed with stock cooler. So then go to www.intel.com, in their search box type "Intel Core 2 Duo 2.4Ghz" and it will bring up all the CPU's and their prices..if you have any questions let me know. Pls rate this solution.
My m2n-mx-se motherboard can't restart it self
DD SYSTEM SOLUTIONS
(MOTHER BOARD CHIP LEVEL SERVICE CENTRE)
OLD NO.28, NEW NO.67, II FLOOR
SESHA CHALAM STREET, SAIDAPET,
CHENNAI - 600 015.
PHONE NO : 98405-11595
May 04, 2009 | ASUS M2N-MX Motherboard
NO USB WORKING
Hi there what OS do you have loaded?
Im assuming you have XP loaded.....
have you tried to unistall and reinstall the USB ports?
reboot and restart,
should auto recognise the device and self install,
reboot and restart,Test usb
dont for get SP2 updates for functionality of the devices
Let me know the outcome thanks
Jul 21, 2008 | ASUS P4P800-MX Motherboard
ASUS P5VD2-MX SE Motherboard CPU compatibility
Hello itsme99, click on this link I have posted. This link shows what CPU you're Asus P5VD2-MX SE motherboard can run.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5VD2-MX%20SE
You're board does not support Quad core CPU's!
This next link is the main page (Drivers, FAQ's ect.) for the Asus P5VD2-MX SE motherboard. (Look to the left of the page under Related Link). http://support.asus.com/download/download.aspx?modelname=P5VD2-MX%20SE&SLanguage=en-us
Here is a list of Asus Quad core motherboards.
http://event.asus.com/mb/quad_core/
Have a nice day.
Enjoy!
M
Jun 06, 2008 | ASUS P5VD2-MX SE Motherboard
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
Bios update
make sure your bios is an eprom. people download bios upgrades only to find their bios is not a flash bios. that is it doesn't have the infrared source to physically "flash" the chip.
Sep 13, 2007 | ASUS P4S800-MX Motherboard
ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/ VGA/ AUdio/ LAN/ MATX (GXMBP4P800VM) Motherboard Logo
993 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
