Question about Maytag Washing Machines
Hi my name is Christine, the last couple I times I did the laundry I have noticed I have to close the lid a little bit harder then normal to get the washer to start
  • Timandthemrs Jul 16, 2008
    Ty for your assistance. I will have a new lid switch installed and see if it helps.
  • 254 Answers
You lid switch is probably going bad.
Posted on Jul 15, 2008
Ran one load of laundry in washer, started another and the unit just beeps 3times and I push to reset but lid won't lock or start cycle. I tried moving dials to wake up machine but got no luck
My GE top loader has a little "finger" on the lid , when lid is closed it depress a switch inside a little hole , Now YOU with a wood pencil you turn machine on and press the little switch inside the hole, it may have dropped too low for the "plunger". the washer should start. now tighten the screws for that switch.
Jun 03, 2015 | Frigidaire FFLG1011MW Gas Washer/Dryer...
How do I open the lid
lid lock needs replaced
Feb 28, 2015 | Simpson Washing Machines
Door will not lock unless you push extremely hard to close it
It sounds like the lid is warped or bent sometimes by putting basket on top or laundry detergent. Also sometimes kids sit ontop
Sep 12, 2014 | Washing Machines
Simpson esprit 550 manual
The lid is a little bit rusty that it does not close properly making the lid switch to be inoperative. I suggest you should try to clean and derust the lid and make sure that the lid switch is actuated when you close the lid. I have to warn you though that these items are usually powder coated so you will have to be good in repairing powder coated items.
Mar 13, 2014 | Washing Machines
Recently our LSQ8243H Washer stopped in the middle of the cycle. The first couple of times it happened all we had to do was open and close the lid and everything was fine. Now it stops and we have to...
Hi, I'd like to help diagnose your problem but I may need a bit more information. Based on what you stated, I assume you have a top loading WHR washer with an electromechanical timer... the kind that you turn and it clicks. Anyway, you stated that the washer stopped in the middle of the cycle and that simply opening and closing the lid would fix it for a while. I suspect that your lid safety switch may be cracked and isn't being actuated by the plunger on the lid. If this is the case, the washer would function properly until it reached the point in the cycle where it should spin. Then it would stop at that point in the cycle. This makes sense that opening and closing the lid might "fix" it for a while. Also, if the switch got bad enough that opening / closing the lid didn't work anymore, you could rotate the timer dial just past the spin area and the cycle would continue. Have you noticed the clothes are wetter at the end of the cycle?
Anyway, check the lid switch first and then repost if you rule it out.
Good luck.
Jan 18, 2011 | Whirlpool LSQ8243H
When i close the lid, it will not start. Only when I push down on the lid several times, will it start. Getting harder and harder to start.
Lid switch is broken...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Whirlpool Washing Machines
High-pressure cooker exploded
most of the time NO but i would try setting it in place and locking down the lid and do nothing for a day or so , do not heat it ,just leave it . after a day remove the lid and see if the gasket looks normal if not REPLACE IT ......... what do you have to loose , just a little time , but just so you know those gaskets dont last forever , your should get one if you can ,just to have in case
Jan 16, 2009 | Crock Pots & Slow Cookers
My Zanussi fridge/freezer is making a funny little noise
What you may be noticing is the system going through a defrost cycle. Check the time of the day that you notice this event. If it happens at the same times it could be a normal situation if at all other times normal temperatures are being maintained. A popping sound can be caused by thermal expansion during the defrost.
Sep 13, 2008 | Freezers
How to replace dust bin lid
With the lid you need to force it on a little bit its tough plastic but dont force too much.
Removing with out breaking is harder. why do you need it off?
Jun 28, 2008 | Dyson DC14 All floors Bagless Upright...
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
