Question about Curtis Sylvania CD/Shower Radio/LCD Clock Personal CD Player
I have a Gainsborough 2000x shower that operates only by pulling the cord that leads into a seperate plstic ceiling casing. The cord will not pull or switch shower to ON any longer, therefore the shower does not work (and it's fairly new) But it hasn't tripped in the mains box so I've ruled out fuse renewal. Also,have tried to unscrew the ceiling box that the cord runs from inside and down; however the screws came out yet the bottom of the casing did not part from the top bit and I did not want to force it, so could not see inside it. Any ideas anyone please ? I'd be most grateful, lost without daily showers !
  • 3 Answers
The pulll cord white box connected to the ceiling, does this have a light on it?
Posted on May 07, 2010
Why is my Gainsborough 2000x shower not heating the water passing through?
I sounds as if the element has failed... if you isolate the power to the shower you could test the element with a multimeter..
Apr 18, 2017 | Gainsborough Home
I have a gainsborough ps1600 shower. Water pressure has dropped. Doesn't help when head is removed. Can still adjust temperature but not speed/power
If the water pressure dropped at a sudden moment, it sounds more like an issue with the water pressure leading into your shower, and not a problem with the shower its self. Try seeing if other water sources in the same area of your shower have the same low water pressure issue.
Stained Glass Leaded Glass St Petersburg FL
Jul 12, 2014 | Home
I have a Mira Vie electric shower, the pull cord no longer lights up, and therefore my shower won't run. I've checked the fuse box and nothing is labelled, it's an old style fuse box. Ther
Buy a current tester( under a tender) and test if supply is going to pull cord (remove the 2screws on cover of pull cord. )Ifyou have power then it's you pull cord that needs replaced if not its mains fuse
Sep 26, 2012 | Home
Shower was working now its not only had it a few months no water coming out no light on but pull cord light is on
Check the electrical output from the pull cord switch to the shower. Both live & neutral
Mar 31, 2010 | Home
Problem with lights on install of a ceiling fan/light
ok...assuming the blue wire is the second wire coming from the light switch, it should be connected seperately to the black wire leading to the light(s). so the black lead of the switch should be connected to the power wire from the ceiling box and the blue wire should be connected to the black lead that goes to the lights. it sounds like you have the light leads connected to the main power, so the light switch would be bypassed, thus not operating correctly.
all white wires should be connected together unless one is being used as a return power from the wall switch, (which is often done).
hope this helps..........................jay
Mar 20, 2009 | Dryers
No water coming out of shower
First you should check the screens st the ends of the hose to be sure they are not clogged. The shower head as well. Otherwise it could be the water control valve, solenoid or thermal cut off.
http://www.theshowerdoctor.com/shower-spares/gainsborough/energy-2000x.html
Mar 02, 2009 | Home
Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Oct 08, 2008 | Home
232 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
