Question about LG 50PX4DR 50 in. Plasma TV
Pink screen on LG 50 inch HDTV
We have been using HDMI input on our LG 50 inch HDTV for over a year now. Yet recently the picture turned "Pink" (black hues shown as pink) with HDMI but not component input. I was interested in your response to a similar problem - where you said that every time this has been a failed pwb. What is the fomal part name for "pwb", and is this board an easy thing to replace for the common electronics DIY person - and where would you recommend getting this part? Thanks for any help -Mark
  • markDIY Aug 21, 2008
    Deepak - I did not buy my TV from Currys - so I can not help you as you seek legal action. FYI and those listening in - my "pink" problem was solved by carefully vacuuming the dust that had accumulated on the housing of the TV and areas near grill intakes. Back in business and everything is working fine.
Lg 42 luv 5500 screens goes pink when turned on.
Try plugging devices into the inputs like DVD, Blu Ray, VCR, Game console, etc. If the screen goes pink on all inputs or at least all the ones you plug anything into (at least 2 different like HDMI and RCA) then it is probably an issue with the screen itself. However it is hard to say when there is so little to go on. information like is there sound or no sound, do you see shadows, outlines etc. or nothing at all, does anything happen when you press menu buttons, will help to see what the problem may be. Secondly how old is the TV? Is it still under warranty or just out? what happened before the screen went pink. what type of TV is it LCD, LED, Plasma, CRT?
If the warranty is still valid go back to where you got it from os contact manufacturer and if warranty is out by about 6 months or less contact manufacturer and try your luck All TVs should last several years at least.
Nov 04, 2017 | LG Televison & Video
Everything working fine, then home screen no longer displays on TV. On startup, pink dots go across TV screen, then TV goes black. Signal from most recent input is not coming trhough the audio or TV.
I have the same problem. I have an LG lcd tv as well. I have my cable box connected to via hdmi into the reciever then from reciever to the tv via another hdmi cable. I can watch tv and like the problem above see the pink dots on boot-up but I can't get the home screen to display.
Jan 08, 2013 | LG LHB975 Theater System
LG 50 Plazma screen is dark pink sometimes goes to normal
Might be to some loose interconnection cables. Seek tech support.
Jun 09, 2012 | LG 50PS60 50 in. Plasma HDTV
Pink color horizontal lines comes on and off
That issue is with one or more of the board that drive the plasma screen. If you have a warranty, you will want to call LG for a free repair.
Sorry, but to trouble shoot that issue would require some TV tools and knowledge of electronics. There are several boards involved with processing the picture image to the plasma screen.
I hope this information has helped you.
Good Luck.
May 24, 2010 | LG 50PS60 50 in. Plasma HDTV
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Changed Lamp on KDF50E2010 now have pink band
Is this on all inputs.If so optical block could be bad.
Apr 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Dec 13, 2008 | V, Inc. Vizio P50HD Plasma Television
Pink screen or scambled picture when turning on tv to watch dvd
I have seen several LG plasma that have a pink picture and everytime it has been a failed control pwb. This bd is located under the assembly that houses the main digital bd. The main dig. bd is the one with all of the inputs.
Feb 08, 2008 | LG 42PC3DV 42 in. Plasma EDTV
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Dec 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
LG 50PX4DR 50 in. Plasma TV Logo
824 people viewed this question
Computer Repairing
Computer Repairing
