Question about Black & Decker Quick Press S560A Iron
#F975 quite press
Heats up for about one mitt. then shut off
We have the exact same iron doing the exact same thing... NOBODY has a soluntion... Black and Decker support can't help either, so... best solution is to take it back where you bought and tell them it's a piece of **** and go somewhere else to buy a different one!
Posted on Oct 12, 2008
Why steam iron won't heat up
if there is no light or heat even when the thermostat is switched to the hottest setting then assumption is that the iron is defective.
with the iron not plugged in check the cable and see if it is worn or kinked or cut. look for any burn markings on the plug. if the iron is some years old it may also be that the element has burnt out. this happens more often in areas where water scale is high.
I hope this was useful.
May 12, 2014 | Applica Black And Decker F975 Steam Iron
Cannot get black stains off with the cleaner kit from Rowenta that I bough at Bed Bath and Beyond. Used almost all of the cream and still not clean. adjina39@aol.com
Are you heating up the soleplate first to get it really hot, then put on an oven mitt to protect your hand, squirt cream onto a folded pad of clean cotton fabric, then apply to iron sole plate, rub over stained area gently, wait, then rub off. you may want to rub the whole iron sole onto a piece of waste fabric to remove the burnt bits. Itcan take a couple of goes to clean. The ironing press cleaning sticks work well too.
Nov 03, 2013 | Rowenta Irons
I have black & decker x950 steam iron, it does not heat up properly. It heats quite low and turns shut off. Again on and shut off. How i can adjust its thermostat for more heat. HELP.
1) no voltage to receptacle
2)defective cord, or terminal connection
3) open thermostat
4) open heating element
see the diagram attached.
God bless you
Sep 09, 2012 | Irons
After the iron is hot and in use for 20 minutes or so it justs shuts down abd the lights stay on but the iron quits
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 29, 2010 | Euro-Pro Shark GI490 Iron
The automatic shutoff won't let the iron heat up
you either need to press a small button on the protection to reactivate it, or buy a new one and replace it. But first check the thermostat, since there is a reason for all this. Check also the heating element with an ohmmeter.
Nov 08, 2009 | Black & Decker Steam Xpress AS250 Iron...
The auto stp security light is on and the iron does not heat up i have a tefal ultra glide iron
i'm not quite sure what the STP security light is but on my iron a security light comes on when the iron is idle. It shuts the power to the iron when no movement has happened mine is about 5 mins.
Sep 16, 2009 | Tefal UltraGlide Easycord FV4256 Iron
My singer magic press 4 iron comes on but the plate will not heat up. I turn it on one day and it just would not heat up.
Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
Jun 18, 2009 | Singer CSP1 Iron
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
My yamata fp202L
Most likely it is the fuse that regulates the heating element on your press that has burned out.
All you have to do is open the top, remove the heating plate. The fuse will be on the left, button shaped.
Replace the fuse and put everything back together and the unit should work.
You can buy a fuse from the company you bought your press at or contact the manufacturer.
Sep 10, 2008 | Yamata FP202L Cordless Iron with Auto...
Black & Decker Quick Press S560A Iron Logo
85 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
