Disk read error no recovery cd
When i start my dell c610 windows 2000 pro laptop i get a disk read error accured. i dont know how to fix it. and i dont have a cd since i bought it used please help. ps i cant get into safe mode. only f2 and f12
  • 4 more comments
  • rocker20066 Jul 17, 2008
    i have a usb drive, not a floppy disk drive though......and what's the bios
    i have a usb drive. not a floppy disk drive, and what's the bios???
  • yudevon Dec 04, 2008
    my dell laptop had kinda stopped reading disks, if i put a cd in, i doesnt show up in the(D:) drive, what will i do??
  • Hitesh Thappa May 11, 2010
    do u have a bootable floppy disk or usb drive which can perform a check disk on your system.
  • David
    David May 11, 2010
    can you get into the BIOS
  • 781 Answers
The BIOS is hard wired into the motherboard and contains all information about the hardware on M/board.usually accessed by pressing del key or f2 key you will have how to do this at the bottom of the boot up screen read all info carefully it should list what your hard drive is and how big
also if hard drive is automatically detected
if you access it set it for default loadings and try again to boot
Posted on Jul 17, 2008
I had Dell Windows XP along time ago. I now have Windows Vista Business and I think it is Service pack 1. I pressed F12 and did diagnosis then it scanned right off the bat it says... "Error Code...
Hi. Error 0146 is pertaining to a failing hard drive. You can still try to reinstall Windows Vista by requesting for a CD from Dell by contacting them.
If they fail to send you a CD or if the error still comes up after reinstalling Vista, then you need to replace your hard drive.
Feb 06, 2011 | Dell Inspiron 1501 Notebook
I have a dell inspiron 8500. Occasionally it would go through post and come up with disk read error press ctrl alt del to restart then it came up with the ntfs.sys file was missing. I manually reinstalled...
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 12, 2011 | Dell Inspiron 8500 Notebook
I have a dell latitude c610 and when i turn it on the first dell page comes up the installation bar fills up and the page goes black,it does this over and over again and will not load.
if you have windows xp bootable cd boot from the disk and choose the recovery console option and type chkdsk /r /f in command prompt and let him complete the scanning.
Dec 31, 2009 | Dell Latitude C610 Notebook
Dell b130 internal system restoration failed
Incase you don't have any thing important on the computer try a factory restore. This will wipe out everthing and make the cmputer like new. To start it power off the laptop. Power it on and hold down ctrl and tap f11 severl times at the Dell logo screen. Try this q couple of times as it may not work the first time. If this does nothing you'll need the os cd (xp cd) tO repair or reinstall windows.
Aug 07, 2009 | Dell Computers & Internet
Activation key on old Dell from win2k to xp
if you do a clean install from a disk thats not a dell disk, it will then ask for the code.
May 22, 2009 | Dell Latitude D600 Notebook
Hard Drive Read Failure
No--I would say that the hard drive has gone bad on you.
The BIOS can see a hard drive, but it can't tell if it's any good.
If it's defective, well--you see what happens!
Mar 20, 2009 | Dell Latitude C610 Notebook
DEll Latitude c610 laptop computer
put in the windows 2000 or xp disk
98 is not supported by microsoft , youll have many problems online
but you need to format the hard drive , 20 gb is good
with the windows xp cd boot from it
you will see just one letter drive if more delete them and format just one drive, you can use the quick format , so the windows xp files will go on after that, but youll have 30 day trial
Jan 27, 2009 | Dell Latitude C610 Notebook
Dell "Drivers and Utilities" CD
Hi, the "No Diagnostic Utility Partition Found" is returned because your laptop does not find the recovery partition on C drive.
Easiest way to create partition is with dell recovery cd. You can buy CDs from dell, buy finding contact on web site or buy from one of the following.
Dell Restore Disk: XP Pro SP2 for ... $35.00 - DIMOSOL - Digital ...
Dell Latitude D600 XP System Recovery CD ... $18.95 - recovery-cds.com ...
Dell Latitude D600 Vista System Recovery ... $18.95 - recovery-cds.com ...
Buy recovery cd according to windows version on sticker at the back of your laptop.
With recovery CD you wont need drivers.
Alternative solution is downloading drivers posted by Maanita after installing Windows from a generic Windows setup CD.
Aug 13, 2008 | Dell Latitude D600 Notebook
Problem with using my recovery CD
I dont know which computer you have but some computers have a built in Partition that has a Recovery and can be accesed when you turn on the computer and can do a recovery that way without using the recovery cd's. It all depends if we are talking about windows, or vista or sony, hp, dell , toshiba etc. I can tell you that if you just want to use your recovery disks it will erase all the personal data on your computer unless you back it up before hand, If you dont care about the data you can put the cd into the cd-rom and when the computer boots either press ESC key or F12 for Toshiba / Dell or F10 whichever is the CDROM boot key. Depending on the model sometimes the BIOS default is set to boot off cd rom and you wont have to press anything. After that you can follow the prompts for recovery it should be user GUI (Graphical User Interface ) Friendly.! Hope this answers your question.
Aug 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
When i start my dell c610 windows 2000 pro laptop i get a disk read error accured. i dont know how to fix it. and i dont have a cd since i bought it used please help. ps i cant get into safe mode. only f2...
That means your hard drive has crashed and you will have to replace the drive. And, since you don't have the cd, you will have to get an operating system to go onto it once you replace it.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
