Question about Microsoft Xbox 360 Console
No Sound on Xbox 360
No sound with my xbox 360 on my new Philips HDTV. I have the red, blue and Green pluged and I also have the red and white cables pluged in also but still no sound.
I think the cable is working because I used to have the yellow red and white cables pluged in the scart connection and straight into my old TV and I had sound and picture.
Any help would be great its really starting to anoy me that I cant have a go of my new TV
  • Anonymous Jan 10, 2009
    I love you guys! :D
    Scholar:
  • 67 Answers
Very often on HDTVs there may be more than one YPbPr connection... That is the Red Green and Blue. Under each one, or next to, or above, there should be separate red and white audio hookups for each set of YPbPr hookups.
Make sure they are hooked into the corresponding plugs.
Hope that helps.
Posted on Aug 21, 2008
    Scholar:
  • 31 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Sound but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem.
Posted on Mar 06, 2009
  • 22 Answers
Well since the red and white cables are used for both Standard TV and HDTV, we can conclude they work!
Double check the Audio Inputs on your TV - they might be for something other than Component (which are the red blue and green connectors), and the component audio in may be elsewhere.
Posted on Jul 17, 2008
How do i connect xbox to akura apl3268fd4 tv so its in hd
There are two ways to connect it.
1. The cable that came with your xbox should have two sets of plugs on it. One being the red, white, yellow and the other red, green, blue. You need to plug the red, green, and blue plugs into the tv with the same color plugs. You will also have to plug in the red and white for sound. The yellow plug is not needed. There will also be a switch at the base of the cable near the xbox. That needs to be set to HDTV. If your cable does not have the red, green, blue you will need to buy a cable that does have them.
2. You can use an HDMI cable. With that all you need to do is plug one end of the HDMI cable into the xbox and the other into the tv. Not all xbox's have the HDMI output though. If its new i should have it on the back of the xbox near the normal tv output slot.
If you use the red, green, blue you will have to set your tv on the component channel. If you use HDMI the tv will have to be on the HDMI channel
This will give you a more thorough explanation. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/audio-video.aspx
If you found this helpful please give me a good rating. Thanks hope this helps
Nov 21, 2010 | Video Game Consoles & Games
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
No video but i have sound
Check the A/V cable where it connects to the Xbox. There is a sliding switch with two positions: TV and HDTV. If you are connected to the tv with the yellow cable (with red and white cables for audio), make sure the switch is on "TV". If you are using component cables for video (the red, blue, green ones), make sure the switch is on HDTV.
May 02, 2010 | Microsoft Xbox 360 Console
No video but sound
its the video chip in the console buy a new console its not worth the cost or the hassle for the price of them these days
Jul 13, 2009 | Microsoft Xbox 360 Console
XBOX not connecting to LG flatscreen -no visuals only sound
There is a switch on the cable where it plugs into the XBOX that says HDTV/TV please make sure that it is set to HDTV when using component connectors.
May 13, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
When connecting XBOX live to LG flatscreen there is no video only
There should be a switch on the cable that says HDTV/TV if you are using component connections, make sure that the switch is set to HDTV.
May 12, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Xbox and tv = no sound
Yes, those cables are quite common. Check any electronics retailer like Best Buy or Walmart.
Aug 25, 2008 | Microsoft Xbox 360 Console
I Have Sound But no picture and xbox unreadable disc
Double check you a/v cables connections.red white yellow for regular tv and red blue green for hdtv. also check the tv/hdtv switch on the xbox end of the cable.Try swapping cables with a friend that has a working system and see it works.
Dec 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,937 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
