Question about Fisher Televison & Video
Fisher digital slim 1400bl from radio shack, they wont help repair the motorized cd door broken from bottom and tried to glue to repair it doesn't allow the cd to work it was broken by 4 year old 1 week after purchase and radio shack didnt have a suggestion thought I'd contact someone before I wasted all that money and tossed it. Thanks
techman
  • 3130 Answers
SOURCE: cyberhome,dvd300
These units can be hard to get parts for, but there is a site dedicated just for the cyberhome products. Try here http://cms-system.cyberhome-dvd-help.com/ Good Luck please do not forget to rate this thread.
Posted on Dec 15, 2006
sanjin
  • 56 Answers
SOURCE: broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Posted on Feb 19, 2008
Mechanic688
  • 204 Answers
SOURCE: Radio Shack Pro-26 Scanner Not Receiving
Hello dino, It sounds just offhand likethe scanner is just getting tired. Maybe a componant failed or changed value inside on the circuit board, that will change the whole setup. It will no longer be fine tuned for the correct freq. range. Hope this helps,,, I know it's not what you wanted to hear.Mechanic
Posted on Nov 01, 2008
  • 10 Answers
SOURCE: need 4 digit code for magnavox tv have radio shack 3-1 remote
radioshack.com has pdf of all manuals with code.
Posted on Nov 22, 2008
SOURCE: radio shack pro 46
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=20-305&Name=Radio%20Scanners&Reuse=N
Posted on Apr 15, 2009
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
I have a Sanyo unit (same as Fisher Slim-4000). It was unplugged during a renovation and when I plugged it back in it was making a funny noise. Couldn't get it to go back to CD mode and when trying...
inside the rubber O on motor that controls the door open and close got uncoiled it should look like a side ways 8 and have that twist on it took me forever but i figured out thats why my door wasnt closing not enough pressure on rubber belt to pully u need to just put that twist n it should work good luck!
Sep 14, 2011 | Fisher SLIM 4000 Shelf System
Where can I get a new remote for my Fisher slim model 1400 bl cd player and radio?
Greetings! Did you ever find a replacement remote? I just bought a Slim-1400 at a thrift store but it lacks the remote. I've been searching for quite a while without any luck. If you had success, can you let me know at RSutherland@USA.net?
Sep 08, 2011 | Fisher SLIM-1400 Shelf System
Lost manual. Need to know how to change th pre set radio stations and set the alarm.
The user manual for the SLIM-1500 can be downloaded here:
http://www.amazon.com/Sanyo-SLIM-1500-Fisher-Executive-Microsystem/dp/B00000J4G0
Hope this helps,
Chris
Mar 01, 2011 | Fisher SLIM-1500 CD Shelf System
Battery door broken
The best is to piece up the broken parts and GLUE them using good super glues available in the market. If the broken pieces are beyond repair then the door must be sourced from Vivitar.
If an old one can be found from any dealer it will be worth a try.
Feb 04, 2011 | Vivitar ViviCam 6320 Digital Camera
This Fisher slim 1500 has never been used. I can't turn it on or make the cd work. I can't even turn on the news in the morning. I installed batteries, hung it on a wall and now it won't work at all. I...
For Fisher SLIM 1500SL model, I figured it out as below.
1/-Plug into AC & you will see Standby ON with AM 12:00.
2/-Press Timer button & you will see TIMER at left top corner.
3/-Press and hold Standby button until entire screen is ON & Standby goes OFF. Everything will go from here- play CD, radio, etc.
Goodluck.
Sep 22, 2010 | Fisher SLIM-1500 CD Shelf System
I moved and lost the power cord to my shelf unit!
Try any flea market or Radio shack. You should be able to find a similar cord on a different radio
Jan 22, 2010 | Fisher SLIM-1500 CD Shelf System
Door shelf support broken
Hi Shari. Yes. Go to any hardware store, or a home depot or lowes. Go to the adhesives isle. What you need is an epoxy adhesive that will work on plastic. There are different ones that will work so read info on the containers to find the appropriate one. One I use a lot with success is called JD WELD.
May 03, 2009 | Fisher and Paykel Active Smart E522B...
Cd does not spin
the motor will need to be replaced
Apr 15, 2009 | Fisher SLIM-1500 CD Shelf System
Need owners manual
This Unit is the same as a Radio Shack RCA branded model minor differences. 42-7011 Same type of issues that the RadioShack unit had. Hope this helps.
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=42-7011&Name=CD%20Players&Reuse=N
Aug 26, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Televison & Video Logo
156 people viewed this question
Top Fisher Televison & Video Experts
matt martin
matt martin
Mike
romy sibug
romy sibug
Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
