SOURCE: HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
SOURCE: I WANT TO OPEN THE LACIE 500 GB HDD AND USE THE
Go for it. There's a chance the internal drive will be PATA (IDE) but odds are good it's a SATA drive with standard connections.
Make sure your PC has connections for SATA drives, and you'll need to buy a SATA cable since the one in the LaCIE case won't connect from your drive to your motherboard.
SOURCE: we purchase western digital 500 gb hdd when pc is
The blinking of the lights is just the indication that data is being accessed.
SOURCE: When I plug my Maxell 8Gb 360 usb thumb drive into
Your PC is infected ,which is running for XP 7and you should remove the virus.
Please download f-secure bootable disk and clean at the time booting.
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
start>program>accessories>system tools >system restore >set earlier date. If you have the strong
virus you can not do that.
You will take more infomation click here
Hope it will help you.
Good by
SOURCE: maxell max data 1tb hard drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working
ports (com&lpt) right click update driver
click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
