Question about Toshiba e-Studio65 Copier
Toshiba e-studio 28 copier
Just moved and when I put my copier back together(finisher back on machine) I get a message to "join finisher to copier". It is attached but on the finisher PC board lite 3 is steady, lite 2 is off and lite 1 blinks. Can you help?
  • rock401 Jul 15, 2008
    The doors are all closed and no change. Usually when the copier is turned on the finisher trays operate and go into position. They do not even attempt to do that right now. What do the indicator lites mean, lite 1 flashing, lite 2 off, lite 3 on steady.
  • Toshiba Master
  • 19,396 Answers
Check that all the door are well closed and in place.
Posted on Jul 15, 2008
  • Ginko
    Ginko Jul 15, 2008
    You should locate and open the finisher door and then check the finisher. Eventually you will have to remove the finisher from the copier and put it back in place.
  • Ginko
    Ginko Jul 15, 2008
    Note: the finisher/stapler is where the paper come out from.
    Genius:
  • 1,226 Answers
Please do as what is suggested by ginko, since i guess its only a proper positioning of all the part.
cheer!
2 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: e-studio 28 copier
You may hve to adjust the finsher to close with out any force. There has to be a inter-lock switch that has to be closed to show that the finisher is closed.
Posted on Jul 16, 2008
Toshiba estudio 282 has error code cc90--how to reboot copier?
good day cc90 is the top tray of your finisher (sorter) is causing the fault it is usually caused by there was something heavy put on the top tray or somebody bumped the tray. the bushes on the tray that is lifted by the motor are faulty and need to be replaced by a qualified technician if you need to use the machine please switch off the machine and unplug the finisher (sorter) switch on and the machine will work and obviously not sort or staple i hope that this quick fix will help you out until a technician can repar your finisher (the plug for the finisher is at the back of the machine above the power inlet behind a small cover)
Apr 06, 2011 | Toshiba e-STUDIO 282 Black and White...
My toshiba copier keeps saying job status change paper type. how do i get it off that? thank you
Your copier is likely trying to print to a different thickness of paper (ie thick 1/thick 2) then you have in whatever tray it is trying to print from. You will either have to change what is in that drawer via user functions or delete the job and try it again with a different paper type.
Sep 07, 2010 | Toshiba E-STUDIO 720 Copier
How do I move the finishing trays down? Toshiba estudio 520
There is a hole in the bottom of the finishing trays on the bottom left hand side (towards the back of the copier.) If you stick a slender object ie. screwdriver and then push towards the back of the machine it will release the tray lock and you will be able to slide the trays freely.
Sep 05, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
Copier Studio 55 Copier. Disposed of old toner and replaced with new toner. What a messy job. All done and the message is "join finisher to copier" Do not understand message. Please assist.
Hi how are you this is jack
Dear ,
you copier e-studio 65 showing message dispose of used toner.. ok.. Its donot mean dispose all old toner and install new toner... Its mean dispose used toner box... Dispose toner Box is a seprat box copier all garbage toner droped this box and when this box are full then copier showing message please dispose used toner box... please check it and dispose it.
Thanks
Aug 04, 2010 | Toshiba e-Studio65 Copier
Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
Mar 20, 2009 | Toshiba e-STUDIO 282 Black and White...
Toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Nov 03, 2008 | Toshiba e-Studio 232 Black and White...
E-studio 810 problem
There are a couple of different switches that could be out of alignment, or not "making" when you reconnect the finisher. If you will look on the copier, at the latch that connects the finisher to the machine, you will see a pointy shaft about 2 inches long. This rod comes in contact with a switch inside the finisher. There is a metal actuator on this switch that could need adjusting. Not a difficult job, but it will require you to take a few covers off. Also, there is a black push button on the finisher that is actuated when you push the finisher to the machine. If you are looking at the back of the finisher (the side that connects to the machine) it will be on the lower right hand side. It it operated by a connecting rod inside the finisher. This rod could have come loose. Again, not hard, but requires cover removal. Also, when you locate this particular push button, try manualy pushing the switch to see if this makes you message go away.
As for the black spots, this could be any number of things, but I suspect that that it might need a cleaning blade and brush, and maybe just a good cleaning in and around the drum unit.
Hope this helps,
C
Sep 27, 2008 | Toshiba E-STUDIO 650 Copier
Jamming
I have a couple of Toshiba machines with finishers in my office. I don't know if they use the same one as the 28 uses.
Is the rollers where it is getting stuck at have a dark cover with the number 1 on th handle?
Aug 14, 2008 | Toshiba e-STUDIO 28 Printer
E-studio 28 copier
Jul 15, 2008 | Toshiba e-Studio 35 Copier
Changing the Developer on a Toshiba E-Studio28
If you are not a technician I would not even attempt this!
Jun 13, 2007 | Toshiba e-Studio 35 Copier
Toshiba e-Studio65 Copier Logo
1,057 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
