Question about Fisher and Paykel Washing Machines
F & P - GWL10 - Diverter Valve issue
Showed the code for diverter valve. Replaced the valve - still not working. After pressing start, that water will pump in, then it pumps all the water out. It continually goes through this cycle and won't keep the water in the tub.
  • 254 Answers
Sounds like you might have the drain hose too far down the stand pipe and it's siphoning, try bringing the drain hose up a little.
Posted on Jul 15, 2008
Water pumps out instead of recirculating?
It's not your wires faulty.
Is the valve installed the right way.
When diverter valve is powered will pump water over bowl.
Your motor controller board may be faulty,
And need diverter driver parts replaced.
Set you machine to Traditional wash only to bypass
Eco active filling that users diverter valve.
Jul 08, 2013 | Fisher and Paykel GWL11 Top Load Washer
Error code 52
51. (00110011) Phase 5 ECO - Recirculation Fault
The product has detected that it is losing water during recirculation.
Primary Source - Diverter Valve Wiring
Action - Check diverter valve harness is correctly fastened to diverter valve. Check flying lead
in motor controller, and connection to valve next to drain pump.
Secondary Source - Diverter Valve
Action - Check diverter valve resistance. If open circuit (nominal is 1500 ohms) replace
diverter valve. During recirculation, check that water is being recirculated back into the bowl,
and that no water is coming out of drain hose. If there is some water coming from the drain
hose, then the diverter valve could be faulty, or it could be jammed with a foreign object.
Replace diverter valve.
Tertiary Source - Motor Controller
Action - The diverter valve drive circuit may be at fault. If the primary and secondary checks
pass inspection then replace the Motor Controller.
52. (00110100) Phase 5 ECO - Recirculation Fault
See fault code 51.
Apr 02, 2013 | Fisher and Paykel GWL11 Top Load Washer
Replaced diverter valve on worcester 9.24 combi and still only luke warm water
check your expansion vessel is not flat.if so recharge..simple way to check press in valve on vessel if water comes out or little air recharge..if water still in vessel the diaphram in vessel has split so replace vessel?hot water relys on expansion??
Dec 10, 2012 | Water Heaters
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel diverter valve malfunction? or control module issue
If the tab is not broken take it out of the washer and remove debris from diverter valve
Nov 18, 2017 | Washing Machines
Fisher paykal GWL10 top loading washer
Hi. I work on these machines every day.
The problem with your model 10 is that the diverter valve is not in the DRAIN position, so when the pump runs, it is sending the water right back into the tub. The issue is one of two things-
Either the tab on the diverter valve has physically broken off and the machine needs a new diverter valve, or there is a short in the machine's controller and it is sending a constant signal to that valve, causing it to never be in the DRAIN position. When the diverter is NOT energized, the flap is at rest and the water will go out the drain. When the valve IS energized, the water is supposed to go thru the recirculation hose.
You want to check that diverter valve first and formost. That's going to tell you what you need to know. Look closely at it and you'll see if the little tab that goes from the wax motor to the flapper lever is broken off. The diverter valve is located down underneath the tub in the right rear, it has three hoses attached to it and two wires. It's grey in color and the little wax motor is brown.
If you would like to obtain a service manual, you can get them from http://www.fisherpaykelparts.net
Feb 05, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel wahsing machine GWL10 stuck in rinse cycle.
no power from the control board to the diverter.replace control board.it is about $150.00 for the part
Jan 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
I have a gwl10 and during the wash cycle there is water coming in but the drain pump keeps running during the fill cycle.
The pump itself is supposed to run during the fill portion of the REGULAR cycle. It is supposed to be mixing the incoming fresh water with your laundry detergent and pouring the solution on your clothes as the tub rotates slowly. If the water is draining out of the machine, then there has been some sort of issue with the DIVERTER VALVE. It either has a broken lever on it or an object has become wedged in it, holding it open all the time. If you try the PERMA PRESS cycle, you will probably find that cycle will work, as it does not use the recirculate function.
I would check the diverter valve first. You can tip the washer back and remove the hose clamps with no tools and shine a light up inside and look for an object. You also can inspect the lever and will clearly see if it is broken.
If the washer needs a diverter valve, the part number is a 426862P and is easy to change. You can get them from Fisher Paykel Parts:
http://www.fisherpaykelparts.net/111-4/Diverter-Valve-GWL10-11-15.php
They also have downloadable service manuals (but I have pretty much told you what you need here)
Here is the GWL10 manual:
http://www.fisherpaykelparts.net/115-15/GWL10US-Service-Manual.php
Dec 19, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
154 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
