Question about TruTech PLV1615T 15 in. LCD Television
Program channels how can i program all my channels? it will only use part of my channel list
  • kechtlo Sep 07, 2008
    I have the same problem....
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Posted on Oct 22, 2008
  • ckinusawi Oct 22, 2008
    Not sure if this will work for you but it did for mine and it's a Tru Tech 15" LCD HDTV.
On my 7" wide screen model TL7001-TP-ASC with ATSC Tuner. When I change the channel it wont tell me what channel the tv is on and the tv guide wont show. The tv does not show no numbers or letters
LG LED TV won't show program information or channel name ...
www.tomsguide.com/.../54774-4-show-program-information-channel-na...
Oct 18, 2011 - 17 posts - ‎7 authors
I will get the picture/sound (up to 1080i) but i can't get the TV to display the information (What I'm watching and the channel's name). It used to ...
ChanSort download ' SourceForge.net
sourceforge.net > Browse > Multimedia
Rating: 4.5 - ‎23 votes - ‎Free - ‎Windows
Jun 5, 2015 - ChanSort Channel List Editor for Samsung, LG, Toshiba and Panasonic ... ChanSort allows you to organize your TV's channel lists on your PC.
Jan 13, 2016 | Televison & Video
Would like to scan programmed channels
The person who programmed your radio decided if and how the channel scanning would function, and whether or not the person using the radio would be able to program a scan list, and if so, which switches or buttons to use. It was all determined using computer software and by connecting the computer to the radio. Maybe you have a 3-position switch. Maybe by putting the switch in a certain position, you can program the scan list yourself. Maybe when the switch is in the right position, then pressing a side button turns on a green light to indicate that you've just added that channel to your scan list. Pressing the same side button again turns off the green light to indicate that you've just removed that particular channel from the scan list. Do this for all 16 channels, then put the 3-position switch into the scan-on position. Instead of a 3-position switch, the person who programmed your radio may have decided that the 2-position concentric switch would be used for programming your scan list. If you're lucky, then your radio has an LCD display. If so, then select PROG and look for a blinking square symbol to tell you when to program your scan list and look for a letter Z with an arrow on it to tell you that your radio is scanning. On the other hand, the person who programmed your radio with a computer may have decided that you did not need to have and of these options enabled.
Feb 07, 2014 | Motorola Radio Communications
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Channel lock is stuck on
May 28, 2011 | Televison & Video
Television states no channels in list
Need more information on this. What kind of television? What happened previously that could have caused this problem? What channels are you referring to? Are they pre-programmed channels, user programmed channels, auto detect channels? Are you using cable, dish, or whatever? What exactly does it do when you turn it on? What buttons are you pressing on television, remote?
Jan 13, 2011 | Televison & Video
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
All channels locked out pro-2055
I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs Contents You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc. To Lock out an ID while scanning, quickly press L/OUT while the ID is displayed. To Lock or Unlock an ID manually: 1. In Manual mode select any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the bank number (0-9), list number (0-4), and the list status (ON or OFF) on the 1st line, the ID# in the list (0-29) on the 2nd line, the ID on the 3rd line, and bank tag on the 4th line (if programmed). 3. Press TRUNK (each time) to select the ID list (0-4). 4. Select the ID# (0-29) by pressing up.jpg or dn.jpg (or press and hold; faster) then press L/OUT to lock or unlock the ID. An L will appear to the right of the ID# if the ID is locked out. 5. Press MAN to exit programming. To Unlock IDs in a bank: 1. In Manual mode select any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the ID list. 3. Press FUNC then L/OUT (each time) to view the locked IDs. Press L/OUT to unlock the ID. The next locked out ID will appear. 4. Press MAN to exit programming. Note: You cannot unlock all IDs at one time.
Nov 18, 2007 | Radio Shack Pro-2055 Base Scanner
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Favourite setting lost when switched off
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Jun 28, 2007 | LG 42PX5D 42 in. Plasma HDTV
TruTech PLV1615T 15 in. LCD Television Logo
855 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
