Have an overload on a Dolby Digital Audio video reciever RCA model: RT2360/RT2360BK
  • stan_jon Mar 20, 2009
    I have the same overload message on my receiver.
    I think it is a power issue, I checked all the fuses and all good.
  • 682 Answers
Please check your speaker cables for internal short circuit or cable touched each other in receiver rear side=take all speaker cables out and check if overload goen you have cables problem-connect speaker one by one until you find the bad one-try to change its cable first and then speaker itself.----if over load remain you have a problem in your receiver itself.
Posted on Jul 16, 2008
Denon Avr-3200 Dolby Digital not working
What I suggest is that you reset the receiver as you mentioned. If you look in your owner's, there will be a procedure that says, "Return to factory default, or Reset" I believe you have it set wrong, or are not providing it with Dolby Digial signal. Dolby Digital, is not processed by the DSP board(Digital Sound Processor), which handles the THX, Neo, and every other format. Dolby Digital, is one of the earliest form of Home Theater. It has to be processed through the 2 RCA jacks(left and right). It is really not used anymore, in light of Dolby Pro Logic, THX and others.
Dec 14, 2012 | Denon AVR-3200 Receiver
My sub will not work when input is tv/cbl. it works for DVD and CD. My cable box says the signal is Dolby 5.1 but receiver does not show that mode. using RCA jacks for connections. Used to get 5.1 and sub...
hello,if your using rca plugs from the cable box than dolby digital 5.1 will not be present. You need to use either an optical or coax or hdmi cable from source to the reciever to recieve digital audio.
Dec 07, 2010 | Denon AVR-2308CI
Only "L" and "R" show with 5.1 input
This is a new install, right?
What's the DVD player sending out to it? Could be Stereo PCM instead of 5.1. Check its settings.
Feb 08, 2010 | RCA RT2360 System
Problems tuning radio stations from Memory 1
  1. RCA RT2360 Home Theatre in a Box Consumer Electronics Discussions on Home Theater Audio Video including DVD MP3 HDTV ... I thought the new RCA RT2360 receiver took care of audio and video. ...
    forum.ecoustics.com/bbs/messages/3/9749.html - 18k - Cached - Similar pages -
  2. RCA RT2360 review - Home Theater Systems Television: 32-inch RCA TV Entertainment series ... Sound system: RCA Home Theater Audio/Visual Receiver RT2360 with built-in Dolby . ...
    www.retrevo.com/s/RCA-RT2360-Home-Theater-Systems-review-manual/id/402ag601/t/1-2/ - 66k - Cached - Similar pages -
  3. Features and specs on RCA RT2360 Theater System - Home Theater ... RCA RT2360 Theater System product features and complete specifications. ... product reviews and stores ratings on RCA RT2360 and other RCA Home Theater Systems. ... reproduction of the original multi-track layers of audio sound. ...
    www.shopping.com/xPF-RCA-RCA-RS2642-NEO-5-BOOKSHELF-SYSTEM-22342661 - 37k - Cached - Similar page
You have removed results from this search. Hide themLoading...
Mar 27, 2009 | RCA Audio Players & Recorders
Wil not switch to dolby digital mode
You must use optical sound wire in order to reprduce dolby digital......You should have 2inputs on the back for this......plus the signal must be broadcasted in dolby digital.Such as HBO,SHOWTIME....they will tell you before the show comes on whether or not the movie or event is being broadcasted in dolby digital.Your unit will automatically change to dolbly digital once the show or event starts.Just make sure your input on video1,2,or3 is set to optical1 or 2.Just press the "Audio Sel" on the remote to change the audio source.But make sure the optical wire is connected first.....And just incase,make sure you are sending a dolby digital source to the unit from the sat reciever,cable box,playstation2.....make sure the dolby digital/optical option is on.You can find out what audio options you have in the menu screen.........or the redneck way.look on the back of the sat reciever/cablebox/playstaion2 ect...for a red laser light comming from these units.........i hope tht helps.
Feb 20, 2009 | Onkyo HTR500 Receiver
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
May 19, 2008 | Marantz SR-7200 Receiver
Dolby digital signal
yes go in main menu of tv audio output and use dobly digital out ok not pcm anlog ok
Feb 03, 2008 | JVC RX-7030V Receiver
Home Theatre System
Check the speaker wires going to the back of the unit. Any stray wires that cross can and will cause overloads to the audio output IC's. Make sure the wire strands are twisted tightly and then inserted into the spring clips.
Feb 27, 2007 | RCA RT2360 System
205 people viewed this question
 Grubhead
Grubhead
