Question about Toshiba Satellite A105-S4004 Notebook
DVD DRIVE MY DVD DRIVE IS JAMMED SHUT IT WONT OPEN AT ALL AND IT HAS A DVD INSIDE. DAYS BEFORE I PUT THE DVD INSIDE THE DRIVE WAS TAKING A LOT OF PUSHES TO OPEN WHAT SHOULD I DO?
  • chaya50 Jan 15, 2009
    I used your great solution and it worked, but it keeps happening. What can I do to fix this?
    Sergeant:
  • 424 Answers
Toshiba Satellite A105 Drivers download link.
Windows 2000
Windows XP
Windows Vista
Windows 7
Easy come
Posted on Nov 01, 2010
    Master:
  • 505 Answers
There should be a little hole on the dvd drive poke a small pin or paper clip on that hole thats how its opened manually
Posted on Jul 18, 2008
    President:
  • Toshiba Master
  • 1,314 Answers
On the drive, should be a little hole. Take a paper clip, straighten it out, and insert it into the hole. This should open the drive so you can remove your DVD.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 15, 2008
    Genius:
  • 2,028 Answers
There is a small hole in the front of the drive next to the button, this hole is the manual release. Use a paper clip, push it into the hole and the slide will release. If the disc is jammed, you may need to pull slightly on the slide when pushing with the paper clip.
Dvd player is jammed and wont open can you help
try taking the outside cover off then you might be able to manually open it .
Jan 28, 2015 | Philips DVDR3440H DVD Recorder/HDD...
Samsung SH-S223 door jammed open
the SH-S223 has the door problem ( when there is no DVD inside).... specially after using it for couple of months, cuz i had an internet cafe and i had the same problem over 8 DVDs from 10 .... so its a factory problem.... any way here how to solve the problem of your DVD door that does not open even when it has NO DVD inside.. ... to solve the problem... take off your DVD out from the case of your PC. take off the upper label on the top of the DVD u will find a rounded circle (cover) , open it just by making it move in a circular way. under it you will find a circled plastic that has a METAL in the middle remove the metalic thing . and through it away from your window. and put the rounded plastic back (Remember not to put it up side down), then close it as it was.. DONE, for more info mazenaburas@yahoo.com plz if u find this info helpfull let me know by sending an email.... thx
Feb 09, 2012 | Samsung Speedplus SH-S223 22x DVD?±RW DL...
My problem is the dvd tray wont open and i know that we need to use a pin in a pinhole to open it manually..but i want to know how can i overcome this problem totally..i mean, why the tray wont open and...
It's possible that a motor has died, or the tray has come off it's runners. Because of the replacement price of these parts, it's often cheaper to just put a new drive in, than it is to get the old one repaired.
If your confident at taking it apart, then you can look to see if there is a physical problem, but because it's a class 1 laser device, then I really wouldn't recommend you opening it up.
Aug 05, 2011 | BenQ (1650V0C4) Internal DVD Drive
I put a installation Cd in to install a new printer but it was not all the way in and now I can't open the drive back up.
Desktop CD/DVD drives have an emergency eject feature, which requires a straightened paper-clip.
Shut the machine down.
Look carefully at the front of the drive, you'll see a small hole. Straighten your paper clip so you have a piece of wire with a handle. Insert this directly into the hole, and push slowly and firmly. As you do this, the drive tray should open at the same time. Once it's open far enough, grab the tray and pull it all the way out, and remove the disk. The disk may have been damaged by being jammed into the drive, but maybe not.
Apr 14, 2010 | Dell (0F146) Internal DVD Drive
Xbox 360 wont play games
If your Xbox 360 will not read your games this is because of the sensors on the back of the drive taking too much heat.
You need to send it in to get it fixed or you can fix it yourself using a good guide
Feb 05, 2010 | Microsoft Xbox 360 Console
Dvd drive has jammed, and is open about half a centimetre, when it is pushed in it makes a grinding noise like its trying to read a disk but wont click shut or open
Here's the thing...most people and pc makers don't realise you should never push the trays shut. Only use the button to open and close them. The reason being, as I see you have the issue of it, is that the gears can very easily jump. The only way to fix this is to remove the drive, take it apart, {gently} and separate the 2 gears. The one on the tray and the one on the motor. move the tray all the way out, then turn the motor gear all the way around so it matches with the door gears at full out position. close tray. reassemble, put back in and try it out. If all goes well, you just saved yourself a few good bucks. good luck.
Oct 11, 2009 | Computers & Internet
Dvd jam
Using a small needle their should be a hole in the front. This is the safety eject hole that will open the drive 99% of the time. Replacing the drive is just as easy. remove the few screws on the bottom of the laptop nearest the drive and grasp ahold of the bay and slide it away from the computer....hope this helped some....
Kevin
Jan 31, 2009 | Akai LCT3201TD 32 in. LCD Television
Wont Take Cd's
Assuming you've looked inside to see if anything is jammed in it, you'd probably have to take the case off to see if the drive links are broken.
Sep 02, 2008 | Alpine CDA-9855 CD Player
Wont eject
Hi, If there is a disc in the drive it's possible that it has become jammed and therefore will not allow the door to open. If you get a large paperclip and bend out one side you will find there is a little hole in the front of the drive. Insert the straightened end of the paperclip carefully into the hole until you feel resistance. Gently but firmly you will need to apply an amount of force and the door will pop open. Remove the disc and restart the computer, hopefully the drive will now respond as required.
If not then possibly the door mechanism band/spring has become too loose or broken. At least these days CD/DVD drive are not too expensive to replace.
Let me know how you go,
SeaJade
Jan 27, 2008 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Jammed dvd
Open up the unit. Find the DVD carriage you might be able to extract the DVD this way, but if you are not find the DVD carriage load and umload motor and manually turn it. This will eject the DVD.
Aug 27, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
178 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
