I have tried to hookup a chill mat to my laptop and it will not take. Do I have to have a CD to input?
  • 828 Answers
This post does not belong in the A/C catagory.
Posted on Jul 15, 2008
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
How do I get the additional usb ports to work on targus awe0101us1 chill pad
Does your laptop recognize the extra USB ports? If no, try updating your drivers.
Jan 15, 2015 | Targus PA248U AWE01US Chill Mat and four...
Laptop chill mat getting lould and fans needs to be cleaned
It will probably be more efficient and easier to replace the cool mat. They are very inexpensive.
Mar 28, 2014 | Targus Computers & Internet
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
Mar 18, 2014 | Targus Chill Mat PA248U Laptop Cooler
Targus awe81us disassembly
is it catching on a loose connection, have you damaged the bearings? try youtube .
Jan 26, 2014 | Targus AWE81US Chill Hub and Chill Mat...
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Oct 02, 2010 | Targus Chill Mat PA248U Laptop Cooler
Targus Chill Mat. I keep getting error with windows 7 that the device is not working properly. It operates but an error keeps popping up every 10 seconds. So I can not use it. What is the fix?
Belkin makes a surge plug that has usb powered ports.
this is a Gr8 option it takes the poering off the pc.
this should fix ya up.
Good Luck
Happy Computing
Jan 10, 2010 | Targus AWE19US Chill Mat XC for Laptops
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Chill mat
i have 1 as well and it broke too. this is http://computers.pricegrabber.com/laptop-accessories/m/1754767/
right?
if its the cord's thats broken, its most likely the switch, more specifically the soldering where the wire connects to the switch is prolly broken. i just sawed my switch open w/ a knife, and took a look. now if a wire is loose in the switch, u can either solder it back on, or (in my case i always have the fan on anyway cuz of my **** dell computer overheating) rip the wire off the switch completely and just connected it w/ aluminum foil.
Mar 24, 2008 | Targus Chill Mat PA248U Laptop Cooler
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
