Need to know if it's worth trying to get my printer fix
    President:
  • 1,314 Answers
It depends. If your printer cost less than $300, then no. If it's a $6000 printer, then yes. Since you didn't tell us what printer you had, it's hard to ascertain the correct response however I hope thse prices can guide you to your decision.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 15, 2008
B200 error on canon mp560.. Dont know how to solve it
I work for staples and alot of the questions I get about canon printers and error messages revolve around ink cartridges and printer drivers. So if you've already tried those two and your printer is over 2 years old I can tell you it'll probably cost too much to fix to make it worth the cost (as you probably already know) wish I could give you better advice but at the current cost of this technology a new printer could be your out.
Jan 25, 2013 | Office Equipment & Supplies
My arm350n sharp digital copier says that my finisher needs service. is it worth fixing
Honestly, No it is really not worth fixing. Most of the error codes with the finisher deal with the stapler unit and the guides that move for the stapler to work. Do you know if the finisher has all of the up dates installed? If not, it may cost just as much to fix it. Sorry for the bad news... Make sure the copier is OFF and take the cable out of the back of the copier and push the finisher from the copier and use it as a stand a lone copier..... Good Luck
Nov 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
I've got an HP R40 multifunction printer. Yes, it is old, but it don't know of another printer out there that will do what it does. I'm having a problem when I try to copy something, it will scan the...
I had the same problem and HP claimed it was the roller on the feed unit. I do think they are programed to feed a little different for scaned documents than copied docs. HP gave me a new printer worth more rather than even try to fix it. Here is a tip. Take the insurance on the extended protection especially if you have a 4 unit function (fax, scanner, copier and printer) chances are 1 function will break before the end of your extended protection. You always get a new unit, rather than them fixing it. It's really worth the 50 bucks if you buy a high end unit.
Aug 10, 2010 | HP OfficeJet r40 InkJet Printer
Ricoh Laser AP2000 Error Code SC_500
Well, I've never worked on one of these, but you're right it is a "main motor failure" error.
That's a costly repair, no matter what, so I guess the answer is probably "no" it's not worth fixing.
Apr 09, 2009 | Ricoh Aficio AP2000 Laser Printer
HP Laserjet 1300 Broken roller (grey drum) in back of printer
Not worth fixing. That's your fuser sleeve. Printer can be replaced for about $100 these days.
Mar 29, 2009 | HP LaserJet 1300 Printer
Cannot fix alarm
I had the same problem and the only way that I got it fixed was to take it into a service center. Even though it was out of warranty they still ended up covering it which tells me that it is a common defect. I don't know that your problem is the same as my unit's defect, but it is worth a try. When I took it in they didn't know if they could cover it under warranty until they got inside the machine.
Feb 26, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Our printer won't feed the paper through.
The pickup rollers can become glazed or clogged with paper fibers reducing the traction they can apply to the paper.
I am not personally familiar with your printer so I don't know how accessible they are but they need to be cleaned or resurfaced with a compound that bonds to the surface of the rollers and restores their grip.
There is a discussion of this rejuvenator here:
Restoring rollers
Dec 31, 2008 | Lexmark X2500 All-In-One Printer
E3 message
paper sensor not working or sensor need to service
Apr 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
Don't know if it's the same problem i had but its maybe worth a try. Mine is a Canon MP160 but again its maybe worth a try.
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Feb 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Mp 160
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
550
Feb 11, 2008 | Canon PIXMA MP160 All-In-One InkJet...
jasbo
jasbo
