Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
Turning on my tv set
We were watching television, and the tv just went off. when i pressed the power button the green light came on for a few seconds and then off. no picture still. is there a fuse or a circuit breaker on a mitsubishi wt-42313?
  • 3 more comments
  • rustyknox Jul 25, 2008
    My TV is doing the same thing. Turn on - power comes on for a few seconds and then shuts off. Is there anything we can do?? Have tried disconnecting all components, and unplugging TV and plugging back in. Still will not stay powered on.
  • lchs13 Aug 02, 2008
    We have the same problem. The TV just went off and when you press power the light comes on for a few seconds and then clicks off. We can't turn the set on with the remote either.
  • dmwarwick Aug 03, 2008
    We've had the same problem with our TV. We'd be watching tv and then it just went out on it's own. My husband changed some connections and it seemed to be working o.k. for about a week. However, this morning it went out again and now the green light won't even go on. I hope someone can help with this problem.
  • kdormeyer Aug 16, 2008
    I have the same problem which I posted elswhere. WT-42313 will turn on with remote or panel button (green light goes on) but then shuts off after a few seconds. It won't stay on. Just happend as I was watching the Olympics.
  • CharlieBiker Aug 18, 2008
    Another case of the same problem. It went off while I was watching the olympics. It will turn on for a few seconds then turn off again. Help!
Same issue - our successful fix, at least temporarily, is to unplug power cable from outlet for at LEAST 4 hours...pref. overnight.
Posted on Sep 03, 2008
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
I have a rear projection Mitsubishi VS-70803 and fixed it with the help of eagle338 it was working fine for a year and a half. So new issue is I was watching TV and all the sudden i hear a faint spark
The set MAY have the self check feature.
If the set is plugged in and you turn it on and a few seconds later the power light goes off:
On front of set press and hold both the menu and input (device on some) buttons at same time for at least 5 seconds and release both.
Power light should then blink a two digit error code like 2 blinks, 2 blinks a pause and repeat the error for a total of 5 times.
If you get an error code let me know what it is.
May 22, 2012 | Televison & Video
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Ihave a 52 inch wide screem hdtv and the power button want stay on can you help
Please try to reset your internal codes first by pressing and holding the power button for 15 seconds. Watch the lights on the tv set and record how many times they turn green and red.
Jan 28, 2011 | RCA Televison & Video
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
I have a mitsubishi 1080 series tv. I turned the tv off and then I went to go turn it on, now the little green light on the tv stays on for 2 sec. and then goes away without the piture ever coming on.
A hint--if the green power light comes on for a few moments and goes off do the self check this set has.
On the front of the set press and hold BOTH THE MENU AND INPUT (OR DEVICE) BUTTONS BOTH FOR AT LEAST 5 SECONDS. Release both buttons and look at the power button.
If this is the case the power light will blink a two digit error code--most common in this case is 2 blinks, a pause and 2 blinks--it will repeat the code up to ten times.
Let me know if you find an error code or the power light just blinks and never stops.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
132 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
