Question about Kenmore Elite 45986 Front Load Washer
Answering your question
It does not make a ticking sound and the sound it does make is very faint.
    Guru:
  • 1,894 Answers
Make sure the lid is closed. There is a switch inside that completes the connection. Your washer may not spin or agitate if this connection is not completed. Make sure that the speed selector switch is not between speeds. Verify that the washer is not in a soak cycle. You can also reset the water level up or down to make sure that the water level control switch isn't stuck. If you hear a humming sound when the washer is full of water, you may have something stuck in the drain pump.
If one of these is not the problem, check the belt. The main drive motor has two distinct functions. The first function is to spin the basket; the second function is to reciprocate your agitator. Inside your washer's transmission is a crank type gear and connecting rods that are used to agitate the washer, with the spinning coming from the washer motor itself. This usually entails some sort of clutch mechanism. Some things to check if your washer is not agitating and/or spinning are:
If you notice weak or no agitation, the splines connecting the agitator to the drive shaft may be stripped and need to be replaced.
After a lot of use, belts can become worn or damaged. Replace any worn or damaged belts immediately. If you have a broken belt, replace it and check the pulley to make sure it's not seized.
Sometimes the drive pulley can wear out and it won't turn the drive belt. Look for wear marks, pits, or uneven spots. It's best to just replace it with a new pulley.
Many washers use a reversing motor. Sometimes it will continue to work in one direction even if it won't spin in the other direction. If your washer has a drive motor issue, you probably need to replace the motor with a new one. Call a professional appliance repair person to verify this first.
The lid switch is a safety device that's there to protect you from sticking your hands into a spinning washer. If this switch goes bad, the washer will not work. You will have to replace it. It is inside the main housing for the washer, and located near the door frame.
The coupler connects the motor to the transmission. After lengthy use, this plastic and rubber coupler can wear out. If this happens, you need to replace it.
Transmission and clutch assemblies can cause agitator and spinning problems They are fairly complex, so if you suspect you have transmission or clutch issues it's probably in your best interest to call a professional appliance repair person.
please dont forget to accept the solution if you are OK with it.
Posted on Jul 16, 2008
I've got a slight ticking noise, but not at start-up. After the engine warms up, it will start out very faint and gradually get louder. After about 2 - 3 minutes, it goes away. This is a High M
This sounds like a tappet (cam follower/rocker arm) is at max clearance. This can be the sign of cam lobe wear or follower wear on its internal clearances or valve tip wear.
May 31, 2012 | 2006 Chevrolet Tahoe
I have a 1998 Plymouth Grand Voyager 3.3L When I try to start it, it wont. The problem is kind of hard to explain. When I turn the key over it will not start. The battery and altinator are fine. I was...
How about the battery
You do hear a faint ticking
That is the starter solenoid
The solenoids contacts could be
burnt,even though you had the starter
tested.
Make sure that BOTH ends of the battery
cables are CLEAN & TIGHT
May 26, 2011 | 1998 Plymouth Grand Voyager
I have a 1994 Buick Lesabre that suddenly devoloped a knock/ticking sound when the oil pressure gauge reads <40. If I hold the revs up till pressure goes >40 the knocking/ticking dies a little but...
sounds like you are getting low oil pressure, could be a plugged filter or plugged oil sump pick up, filter is easy oil pump required removal of the oil pan
Jul 24, 2010 | 1994 Buick LeSabre
32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
Apr 06, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
My external is making a faint tick, tick, tick
I am sorry to inform you that your drive is failing. Normally drives will start with a faint ticking then move onto a solid clicking sound and maybe even a grinding noise. You will need to backup all of the data on that drive and then download the diagnostic utilities from your drive's manufacture and run the testing tool. If you can hear any ticking there is a very good chance the drive will fail the diagnostic tests. Assuming it fails you will then be able to RMA your drive for a working one as long as it is still under the warranty period. If your drive passes all the testing from the manufacture's tool I would advise you backup your data from that drive regularly and run the diagnostics weekly until it throws and error code.
Jul 23, 2009 | Computers & Internet
My PS2 Slim will play some games but not others. These are all legit games, not pirated. God of War 2 worked last week, it does not work now. DDR still works fine. It seems to spin up, I hear a few faint...
I know this sounds basic and simple, but a ticking noise "generally" is just the disc tapping on the base, make sure the disc is (1) not warped at all (heat can do this for example) or (2) is pressed firmly on the eye. - Sometimes the most elusive answers are simplified with firepower and a good pair of jeans. - Mother Theresa
Jun 12, 2009 | Sony PlayStation 2 Slimline Console
Camera - Canon Powershot S2 IS (5.0)
This is caused by a bad lens motor, contamination in the transmission, or mechanical damage from dropping. The only fix for this is to have it serviced by Canon or other camera repair facility.
Dec 14, 2008 | Canon PowerShot S2 IS Digital Camera
No Picture No Sound
I think you have a short somewhere inyour set most likely the horizontal output transistor which may have shorted by the high voltage transformer going bad. The faint ticking sound that you hear is the power supply trying to start but the shorted load won't let it. Stargazer
Apr 22, 2007 | Samsung TSL3099WHF 30" TV
Kenmore Elite 45986 Front Load Washer Logo
42 people viewed this question
Sal De
fordexpert
Robert Rankin
