Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Changed bulb, still no pic
I changed my bulb, as it was burnt out, replaced, and still wont turn on.
The first lite (red power lite) is on, and the second (bulb lite) is blinking green.
Any troubleshooting tips?
According to the manual the second lamp is indicating that the lamp cover is not closed
Posted on Jul 21, 2008
Tail light wont stay on, replaced bulb didnt help
if this is happening on one side check the houseing where the bulb gos to see if it is burnt or melted on the inside if not turn the lites on move bulb with ur hand if it comes on it may be to lose
Sep 17, 2011 | 2006 Hyundai Elantra
Sanyo plc xu115 new bulb wont fire. power light turns green at first but after a few seconds it turns flashing red. the old bulb exploded on this projector.
Could be a burnt capacitor on the circuit board. Replace capacitor if you can determine which one it is. There are only a few.
Apr 20, 2011 | Sanyo PLC-XU115 Projector
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Brake lights will not work.
check all your fuses if fuses are good check brake lite bulbs see if they are blown. if bulbs are good get a test lite see if you have power to the bulb sockets have friend apply brake pedal you test power going into bulb socket if you have no power brake lite switch behind brake pedal could be burnt out. p.s dont forget to check all fese relays when checking your fuses.
Apr 26, 2010 | 2006 Chevrolet Colorado
How do you change burnt put back up lites in 2003
Open trunk, remove back liner, push bulb in and turn left, then let go and it should pop out.
Mar 23, 2010 | 2003 Chevrolet Impala
60 in sony grand wega
if it turns to red most likely you need to replace the bulb.
Larry D
Aug 15, 2009 | Televison & Video
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
On switch lite burnt out need replacement
There is no light bulb in the switch of the machine. It is simply light shining through the red button that gives it that effect/illusion. If you are able to turn on your machine without any problems it is working as it should. If the power switch is not engaging and the vac is not turning on at all, that's a different issue. In that case call the Dyson Helpline so that they can refer you to an authorized dealer in your area who will fix the switch for you.
Mar 12, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
TV powered off and wont turn back on
had the same thing and took it in to the shop and it was the bulb had burnt out..bulb cost 199.00....hope this helps
Jan 24, 2009 | Hitachi Televison & Video
Wiring problem left blinker does not work properly
bad ground ..trace from bulb area back to fuse block with flashers...wire is shorting to ground or ground is loose.. good luck... also... my 05 ram had wrong sized gaskets around bulbs in back causing bulbs to not last til i discovered it not sealing out the elements and replaced
Jan 07, 2009 | 2001 Dodge Ram 2500 Truck
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
127 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
