Question about Delphi Roady XT XM Radio Receiver
Stations dropped I've had my Roady XT installed for about 9 months now and it has been working great. But now for some reason my radio is skipping over some XM stations. I used to get station 121 (Fox news), but now my radio skips from 120 to 122. This is also occurring with station 8 (the 80's) - when I scroll through the stations my radio skips from 7 to 9. i had XM resend my radio a signal, but it did nothing to solve the problem. Can you help?
  • kbh8 Jul 25, 2008
    I had the same problem with dropping stations. I've had the service for two years with no problems. Then one day I tuned in to find that some stations I previously received and listened to were no longer available, even through direct entry. These stations included 140 ESPN, 143 Fox sports, 127 CNBC, among others. These were all stations that I had preset. Others that I had preset are still available. When I enter '140' in direct entry I get "updating" and then am returned to the station I was previously listening to. Help!
  • rabarnum Aug 30, 2008
    I have the exact same problem.  I lost channel 8, as well as all the MLB channels (170's).  This seems like an odd coincidence.
Go to refresh.xmradio.com and insert your radio ID and click submit. It will resend the activation signal and should unlock your channels within 15-20 minutes.
Posted on Sep 04, 2008
Go to refresh.xmradio.com and insert your radio ID and click submit, it will send a refreshed activation signal to your radio and you should have your channels back within about 15-20 minutes
I can hear a soft squealing noise when my Roady is in the home dock. Also it starts changing stations randomly by itself. Any suggestions?
If you're using XM Direct to input channels, press the select key after tuning to the channel. If you're not, perform a factory reset. The squealing noise is because of interference with your speakers, it's normal (unless you don't hear any music).
Jan 02, 2011 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
Jan 24, 2008 | Delphi Roady XT XM Radio Receiver
When I press the power button the screen flashes once & then goes blank again. Some times I see a quick flash of "XM-Radio" This started happening overnight one night-nochanges on our part.
I had exactly the same problem with my Roady XT. The power supply gradually failed, with the symptom that the reception kept getting weaker and more spotty. Finally, the Roady would not turn on. The screen flashed as you describe. I happened to have another 5VDC, 2A power supply in the closet from some other electronic gismo from the past (I save the power supplies just in case). the connector on the old power supply was not correct for the Roady XT, but a little surgery put the new plug on the old supply... (verified by a volt meter). When I plugged it in the Roady quickly turned on and showed full signal strength. This had never happened in 2 years of use. Apparently this radio needs more power than the stock power supply can provide. Now it "loads" stations in 2-3 seconds and never fades.
Jul 12, 2009 | Delphi Roady XT XM Radio Receiver
Roady xt
i figured it out with help from a delphi service rep.! you need to go into the menu and reset to factory default.this will erase everything you have changed from the factory settings,but once done you can reprogram your settings and they will stay. step 1-enter menu step 2-reset factory default settings step 3-reprogram your preset stations,FM freq. colors etc. step 4-use power button on the roady to turn it off.once the roady shuts down turn it back on with the power button. step 4-now you should be able to turn the key off without erasing your presets.
Apr 25, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT won't turn on
Same here, it's nice to know I'm not the only one with this issue at least; but as to a way of solving this, I've found nothing.
Dec 07, 2007 | Delphi Roady XT XM Radio Receiver
Xm radio
mine does the same thing.
Nov 03, 2007 | Delphi Roady XT XM Radio Receiver
URGENT Belkin F5X007*****Please Read!!!******
same thing happened to me and I had to take the radio back to Walmart...
Jul 22, 2007 | Belkin F5X007 XM Radio Receiver
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
229 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
