Question about RCA RCR450 Remote Control
Help what button is the code search button
  • Anonymous Jul 21, 2008
    need help programming
  • Anonymous Aug 09, 2008
    cant find the code search button
    Problem Solver:
  • 15 Answers
There is NO "code search" button on this unit.
Here is a copy of my previous post regarding the programming of this remote:
The manual for this remote can be downloaded for free in PDF format from:
http://safemanuals.com/user-guide-instructions-owner-manual/RCA/RCR450-_E
I actually found it while searching for the RCR451, but it works on RCR450.
Important !!
1) Press "device" button, release
2) Press "device" and "on/off" at same time until indicator light stays on
3) Press "on/off" until device EITHER turns off or goes to (device) menu
4) Press "Stop" key to store the code
I used this control and method to program a Fisher VCR, a Zenith DVD/CD player, and a Quasar 25" TV.
Good luck !!
Posted on Oct 10, 2008
I lost my manual for my remote control universal Philips I need help for my codes to programming a DVD player Coby 154
My manual lists 0294, 0296, 0396, 0293, 0146, 0494, and 0091. You also should be able to use the code search function to find the code.
Turn on player. Press and hold CODE SEARCH button until red indicator stays on, then release CODE SEARCH button. Press VCR/DVD button once to cause red indicator to blink once. Press CHANNEL UP button (up to 300 times!) until player turns off then immediately press MUTE button to install code.
Good luck with that 300 times!
Sep 02, 2012 | Philips Universal Remote
I need my polaroid rc-201 remote code for rca en-v tv... please help!
  • This is a code search remote. You do not need a code.
  1. Turn on the the unit you want to program.
  2. Now take your remote and hold the "code search" button.
  3. While still holding the "code search" button press and release the "T.V." button on your remote.
  4. Now wait for your "T.V." button to flash once and then release the "code search" button.
  5. Now press on and off on the remote until the T./V. actually turns off. This may take a up to a hundred presses but when the TV shuts off the remote is set.
  6. Use your newly programmed remote.
Regards, Tony
Apr 27, 2011 | Polaroid 1720-7 Remote Control
Trying to program memorex dvd. cant find code, HELP!
Hello
The manual of the remote control you speified here contains no codes lited. But there is a possiblilty to find out the code by search method. If the device you wants to control with this remote control has codes stored in the remote memory, you can exit it by code search method.
Code Search By Brand.
Lets you search for a code for a specific Brand within
the Code Library for a particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red
indicator remains on, then release SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((or POWER or
PLAY (VCR only)) repeatedly until the device to be
controlled changes channel. The red indicator blinks
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
Try this. Good luck.
Apr 07, 2011 | Philips SRU3004 Remote Control
Free list of codes for a magnavox mru3300
I'm not positive but these codes should work, if not try the CODE SEARCH function. I'll post the Code Search instructions first, then I'll post the Brand Codes (list is a bit long so it might take a couple of posts). Let me know if any of this helps you and I'll continue to search for a pdf type of code list for the mru3300 for you.
*CODE SEARCH
If your product does not respond after you have tried all
the codes for your brand, or if your brand is not listed,
try searching for your code by following these steps.
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
5. Press and release MUTE to install the code.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
ANY VCR code in step 3 of Direct Code Entry. Then
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
Dec 13, 2009 | Philips Televison & Video
I lost my codes
USING THE RMC10 REMOTE WITH AN UNLISTED DEVICE.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Most users will store VCR codes under the VCR button, Cable codes under CABLE,
etc. If (for example) you want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and press CABLE in step 2 of Direct
Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search (or Brand Search, below). Note: If the device does not
have a CHANNEL UP button, use PLAY (VCR only) or POWER instead. Code Search
starts from the currently stored three digit number under that mode.
AUTO CODE SEARCH:
your brand is not listed, try searching for your code by following these steps.
2 Press and hold the CODE SEARCH button until the red indicator stays on, then
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator
blinks off once.
5. Press the ON/OFF button down till the Red Indicator Light stays on.
6. The red led indicator will keep on flashing till your device (TV, VCR etc) turns off.
7. Press and release enter to Install the code.
CODE RETRIEVAL:
1. Manually turn on the device (TV, VCR etc) to be controlled.
2. Press and hold the CODE SEARCH button until the red Indicator stays on, then
release the CODE SEARCH.
3. Press the device control (TV, VCR etc) you want to control.
4. Press the CODE SEARCH button again and the red indicator should blink once.
5. Follow the sequence of (0-9)and press once for each number button until the
Indicator flashes one time.
6. Repeat the procedure 5 till 3 correct codes are confirmed.
7. If the red indicator light flashes, than you have entered an incorrect number, and
please follow the sequence (0-9).
also here is your manual. For your remote.
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
please rate me, or recommend me it will be most helpful in letting me and other know how im doing.
Oct 03, 2009 | Sentry SE-RMC10 Remote Control
How do i search for an unlisted code for my universal remote?
This is the web site where I found the codes for mine, http://www.remote-codes.com/universalcodes.htm
Hope this helps, if not, let me knoe the model # and I can assist further...
Sep 17, 2009 | Philips Universal PH301S Remote Control
CODE FOR TRUETECH TV
There are two useful websites that give detailed instructions on how to program your RCA universal remote, even if you do not know the codes:
1) THOMPSONTV.COM/RCARC.HTML
(Use this website's instructions if your remote has a
CODE SEARCH button)
2) WIKIHOW.COM
(Use this website's instructions if your remote does not
have a CODE SEARCH button. Once you are on the
website, type HOW TO PROGRAM AN RCA
UNIVERSAL REMOTE WITHOUT A CODE SEARCH
BUTTON into the searchbox, and start the search. Then
click on the subtitle dealing with searching without
a code search button.
Hope this info helps you out. Please take a moment to rate this solution, by using the rating system below. Thanks.
Jul 28, 2008 | Televison & Video
Reprogramming my remote
i have a oneforall remote control i need to program my rca vhs can you help me find code
May 20, 2008 | Televison & Video
Philips magnavox, universal remote
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Apr 23, 2008 | Philips Magnavox MRU1400 Universal remote...
RCA RCR450 Remote Control Logo
170 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
