Question about GE Profile 20.7 cu. ft. CustomStyle Side-by-Side Refrigerator with Dispenser TPX21PRBWW
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Water is puddling at the left front as you are looking at the doors. Pulled out refrigerator out and checked the water inlet and the tubing leading to the freezer, no leaks noted. Leveled the ice making and am testing now. I did note an ice trail at the bottom of the freezer leading out the door.
  • 5 more comments
  • Anonymous Aug 09, 2008
    Hi, I have the same problem. I looked below the coiles and saw ice hitting the fan. I didn't know why ice is building up so I changed the defrost thermostats. Two days later, water leaking again. Any idea?
  • Franz Barker Feb 08, 2009
    In the bottom of freezer compartment, In the far back is a drain hole. This hole can freeze close. I chipped and melted the ice (Hair dryer), and poured hot water into the hole till it drained into the drain pan. Since then no problems.
  • dhall03 Apr 08, 2009
    We had leaking for a few months. Just poured hot water and a mixture of clorox, hot water and diswashing detergent (careful, this is fairly reactive) down the drain hole as described, and it's fixed! Used a shop-vac in water mode to pull the chemicals and old water out of the drain pan in the back, cleaned her up and she's running like new.
    Very helpful!
  • chessiecat May 11, 2010
    My ge bottom freezer profile model no tcd18padww, did leak, now the freezer has ice on bottom; I've "defrosted" it 2 times the old way. I can't find the drain at the bottom to see is it is plugged. Does anyone know where I can find a diagram of MY FRIDGE? it also "knocks" when it shuts off, so I need a diagram for "continuing" problems.... thanks!!!!!!!!!
  • Anonymous Mar 20, 2014
    water is coming down the front of the refrigerator by the ice and water dispenser
  • Anonymous Mar 28, 2014
    how to remove
    how to remove freezer door
  • 4 Answers
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
  • connexcindy Jan 04, 2011
    Very helpful. Yes, the drain was plugged, and now I understood where the water was coming "from". Just defrosted the hole, and am hopeful with a towel still positioned under the freezer door. But...let's talk about how this happened. I noticed that I had perhaps "overstocked" the bottom freezer door. Could it be that this had prevented the kind of airflow needed in the lower fridge for the proper defrost process? I'll also try to not overbuy so that there's no need to overstock.
Water leaks under bottom drawer of profile side by side
refrigerator.
Posted on Mar 13, 2011
Yes, we had pools of water under the fridge on HW floor!. Read the post here and checked drain hole. Iced over solid! Cleared with little hot water and it's back in business. But the floor is ruined. I don't care for this GE appliance. Other issues (freezes stuff on fridge side) and too small. Going shopping for new.
Posted on Oct 24, 2010
  • 1 more comment
  • sarah281 Nov 27, 2010
    Did you ever get any explanation for the freezing in the fridge side? Ours does this all the time, freezes all the drawers.
  • JWMinaFix
    JWMinaFix Jan 28, 2011
    The water should drain to an evaporator cylinder at the bottom rear of the fridge. The water just dissipates over time. It’s behind the cardboard panel on the back. But you can’t really mess with it. If the hole is plugged, then the water has no place to go but out the front door.
  • JWMinaFix
    I don't think the unit has good air flow to keep things in the back from freezing or the bottom drawers. So we dumped out model and got an Electrolux French Door Model. Love it. Very quiet, lots of room for counter depth model. love the drawer freezer. The GE is a dog.
    New Friend:
Hi ~ We had the same problem. In the back of the freezer below the last tray should be a drain plug. It tends to clog after 3-4 years with hard water deposits... anyway. Get a can of compressed air from your local office supply store and clear the plugged drain. This advice cost me a $150 visit from a service repairman but it works. Good Luck
Posted on May 30, 2013
Where does the water drain to?
Posted on Aug 27, 2010
  • JWMinaFix
SOURCE:
My water dispenser was not working. Tried the defrost trick and still no water. Noticed water under the refrigerator.
The Dispenser supply usually flows through the bottom, inside toward the back to cool the water. If the puddle is near the back. refrigerator section it's probably this water cooling arrangement. Usually. a number of the tubing loops near the back bottom edge. Connections here or tubing itself may leak. It may also be an undetected leak from the Filter housing or the filter is not properly seated or possible filter housing connections. I have had good success with paper towel detection method. Wrap
or paste, tape towel to suspect leak locations. They will soon appear and point to the apparent leak.
Apr 01, 2015 | Refrigerators
Every few days I find a small puddle of water near the front left corner under the freezer of my TFH22JR.
Guys, . . . small puddle of water on the FRONT left side?? Y'know, . . under the FREEZER door??!? Maybe check the John Guest quick connect/disconnect fitting at the bottom of the freezer door just behind the front cover. It may not be fully connected, or may have a seal worn-out.
Apr 12, 2014 | GE Refrigerators
I have a frigidare 20.6 frig. approxiamately 10...11 yrs old im find water puddles on top glass shelf and bigger puddles at the bottom I cleaned as much as I could the fan is working help model...
Hello Donna, I am happy to assist you. I understand that water is collecting in your refrigerator. Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
I certainly hope this troubleshooting tip resolves your concern. If you have any additional questions, please feel free to respond.
Aug 03, 2013 | Frigidaire Refrigerators
Whirlpool refrigerator EL7ATRRMS08 Drip Tube Clogged
Best bet on that is to remove the evaporator cover and pour very hot water down the drain. Should be eight screws. Removing the drain tube should not be necessary to repair your issue.
Mar 13, 2013 | Refrigerators
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
9,894 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Jeff sanchez
Level 1 Expert
