Question about Maytag Washing Machines
What does it mean when nd appears on the led screen on a neptune washer
  • 254 Answers
From what I've researched it might be a drain issue. If your having a drain problem, pull the pump and make sure you don't have something stuck in it.
Posted on Jul 15, 2008
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
WHAT DOES "ND" MEAN
ND is No Drain condition.
It is likely a coin or other object is clogging the pump screen.
You must disassemble the hose(s) on the pump and inspect/clear the blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune Washer showed "nd" on the display screen, and now the door will not unlock. What can I do?
ND is NO drain
The water level fails to drop below the Low Water level reset within 15 minutes, before a spin begins.
Sep 22, 2009 | Maytag Neptune MAH6700A Front Load Washer
What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Apr 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Oct 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Maytag neptune washer code nd, what does it mean
nd means not draining. u may to check the plastic drain pipe in back to back sure it doesnt have a kink in it, and that it is placed so that the pump inside the washing machine doesn't have to pump it too far to get to the drain.
May 03, 2008 | Maytag Neptune Washer
Nd appears onscreen
First drain out the water from the machine with a tube. You have to check your outlet filter, likely it is clogged. Clean out and refit. Your machine will not do the spin because it knows the filter is clogged.
Jun 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
