Honda P0370 - Timing Reference High Resolution Signal A Malfunction.
The optical sensor provides a high resolution signal to the Powertrain Control Module (PCM)
by counting pulses on the sensor disk located in the injection pump.
The high resolution is one of the most important inputs by the PCM
for fuel control and timing. This test monitors the number of high
resolution pulses which have been missed (not detected). It's based on a
comparison between the number of pulses that were detected since the
last pump cam pulse and the number of the pulses that should have
occurred. There are approximately 64 high resolution pulses for every
cam pulse.
Possible Causes:
- Open or short in the optical sensor circuit
- Optical sensor connector
- Damaged optical sensor
- Damaged PCM
- Damaged ECM
Possible Solutions:
- If damaged repair the optical sensor circuit
- Replace optical sensor
- Replace PCM
- Replace ECM
Not sure where you got incorrect gear ratio. This P0370 DTC is for what I have listed above.
Trouble Code Conditions:
Vehicle driven to a speed of 4-37 mph at more than 500 rpm, gear selector in 4th Gear in Drive, and the PCM detected too much difference in the engine speed and output shaft speed.
Possible Causes:
Vehicle driven any forward Gear, and the TCM detected the ratio of the Input speed to the Output Speed did not match the current Gear Ratio (this test can take up to 5 minutes).
Possible Causes:
