Question about Compaq Inkjet Ij300 Printer
Compaq Ij300 Power Adapter
Can anyone tell me what size power adapter is used with the Ij300 printer? It doesn't say anywhere on the printer what the voltage and current requirement is and this printer was given to me without a manual.
Thanks!
  • ms gal Sep 08, 2008
    Need to know what power adapter is used for a Compaq IJ300. Can't print with out power HELP
  • BUBBY31 Sep 19, 2008
    NEED TO KNOW POWER ADDAPTERINFORMATION TO OPERATE MY PRINTER.
The AC adapter for the COMPAQ IJ300 is the Class 2 Power Supply, Model DND-3005, INPUT 120-127V-50/60 Hz 350mA, OUTPUT 30V---500mA, PART # 70D0209, Assembled in China 9933 per my orignal adapter for the COMPAQ IJ 300.
Posted on Jan 18, 2009
Free down load driver for Cif single chip driver web cam
Posted on Dec 14, 2009
  • 43 Answers
It is 300v (UL) STV E55333 LONGWELL-CSA
Posted on Sep 12, 2008
Hp compaq 6737s not powering up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Nov 05, 2012 | Computers & Internet
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
Compaq nc4200 doesnt recognize the new battery i got. when inserted. The charginf light comes on for a few seconds and then shuts off. the battery check doesnt detect it at all....
Use a multimeter to check the jack at the end of the power cord. If the required voltage doesn't reach there, the problem is with the power adapter. In that case, buy a new adapter.
Sep 21, 2011 | HP Compaq nc4200 Notebook
I lost my adapter plug to my printer. what adapter plug do I need. Its a compaq ij300.
Well you can get your adapter plug from the below HP (Compaq) site -
http://h20141.www2.hp.com/hpparts/CountryChoice.aspx
(note. just copy and past the above link in your web browser and then you select your location to get the adapter)
Good Luck!!
Thanks
Jan 16, 2010 | Computers & Internet
We have windows vista and when we tried to install compac IJ300 it only goes up to windows 98 - can we install that using vista???
I found this solution on another website, I suggest you give it a try.
Everything works fine since I installed Vista except for my printer a Compaq IJ300 which is a Lexmark Z11 in disguise. I installed the driver for the regular Z11 through the "Add Printer " but had problems.
Went to Lexmark site - downloaded drivers for Z11 Series ColorFine- working perfectly. So far I have no other problems with vista.
Aug 25, 2009 | Compaq Inkjet Ij300 Printer
Does anyone know what error code 3807 on a Kodak ESP 5 all in one is? And....can anyone tell me why the dammed thing tells me the print head is not installed every time I turn it on?
found a solution for your error code 3807 "System status failed"
To resolve the error condition:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
  4. Wait until the printer is ready to use.
If the error condition continues:
  1. Remove and install the Printhead two times before closing the Printer Access Door.
  2. Wait until the printer is ready to use.
If the error is not resolved, contact Kodak.
Jun 21, 2009 | Kodak ESP 5 Printer
Cpqusbfw usb hub
i have one of those hubs the ac adapter is output +5V, and current 0.2 - 2.5A, inside of connector is pos(+), outside is neg(-), input: 100 - 120 Vac and 0.45A Max
Aug 30, 2008 | Micro Innovations Compaq CPQ24USB
Compaq
Something similar happened to me with a Lexmark P122 which uses the same cartridge. I believe Lexmark also makes your printer. Did you check the simple stuff first? Shut down your PC and printer, unplug your printer cable, check to be sure it's clean and in good shape on both ends. You can used canned air to blow out the connections. Remove the cartridge, don't touch the copper part with your hands but you can use a lint free cloth with isopropyl alcohol and lightly wipe clean all the copper contacts. Reinstall the cartridge and cable, start your PC and let it boot normally, then start your printer. If you have the same problem, it's probably the printer cartridge itself. On my P122, it turned out to be the printer cartridge. Probably some shorted lands. And that in turned caused my printer to fail permanently. Is there a light flashing on your printer in a short/long type of sequence? If you don't mind, can you check the power adapter (the black box connected to the electrical outlet and supplies power to your printer) and tell me what it says following the word OUTPUT?
Jan 21, 2008 | Compaq Inkjet Ij300 Printer
Black cartridges won't print. Color cartridge works.
Why dont you go to the store that you bought the printer from and ask one of there people there fix the problem..
Dec 28, 2007 | Compaq Inkjet Ij300 Printer
Power failuer
First off it?s a fairly risky proposition to plug a power adaptor from one device into another without making absolutely sure it supplies the correct voltage, amperage and has the correct polarity. Your laptop needs 18.5 volts, 3.5 amps, and approximately 65 watts to charge the battery. If you power adaptor is less that 3.5 amps it will shut down to prevent any damage so that?s probably what is happening. I would suggest going to the HP (now owns Compaq) or Ebay web sites and purchasing a replacement there.
Jul 24, 2007 | Compaq Evo N610C Notebook
Compaq Inkjet Ij300 Printer Logo
503 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
