Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
I need a new program of when shows are on the air. It seems some of them have changed times, such as The Lone Ranger. I need something to tell me when the new times are. Gail Wendover
Have fire and gas. airflow seems to have reversed. Intake pushing air out, any ideas.
If you know for a fact the timing belt is ok and cam timing is correct, I would say its a stuck or bent intake valve or two.
My first guess would be a damaged timing belt tho.
Feb 28, 2016 | Cars & Trucks
I am trying to create a video but I am being told my project is too lone. I have cut it down to 43 minutes but it is still telling me it is too long. Can you tell me how to fix this?
You don't say what program you are using, or on what equipment. I find that if I have video I am making into a project, and it involves many adjustments to clips, etc. that I need to save each modified clip and add that to the next modified clip if my software can't handle large amounts of changes all at once. So modify, save as something new, add to another modified clip, and save a new, then keep building your project until it's length had few modifications and it's real work is simply adding video you have already modified together with each other. Good luck.
Oct 19, 2014 | Cameras
Does the 75th anniversary edition of the Lone Ranger have subtitles in Spanish?
Yes. This DVD comes with English, French and Spanish subtitle options.
Feb 16, 2014 | Genius Lone Ranger - Dvd
How do I deprogram my noma thermostat. It goes to 20 dgrees at 6:30 am( as I had programmed it to do last year ) I would also like to see what programs are in the thermostat now and erase them all. Ho
Here's a link.http://www.ehow.com/how_7893559_noma-thermostat-instructions.html Seems your not the lone ranger on these Noma's, read the link.http://forums.redflagdeals.com/noma-programmable-thermostat-need-help-231181/
Oct 27, 2012 | Heating & Cooling
2002 ranger 3.0 vulcan with 90k miles has been running sluggish, mostly on highway. Just no power. I am original owner and I know this is no rocket, but somethings wrong. No codes, new plugs and wires at...
Could be a handful of possibilities: When was last service - tune up and filters changed? Sluggish on highway suggests possible fuel filter. For the record filters, plugs etc should be changed every 30k. From what you're telling us, you've been running on borrowed time.
Jan 03, 2011 | 2002 Ford Ranger Regular Cab
Flashing time on a Hunter Programmable Thermostate #44665
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Jul 22, 2010 | Hunter Fan Company 5/1/1 Programmable...
I have put new ink cartridge in and it does not recognize them, showing that they are all empty
A lot of these new printers can't actually see if there is ink in the cartridge. They run something like a drip count that counts every time the cartridge prints something. I think the way this works is when you install the cartridge you have to tell the printer that you did so and it resets the drip count. You didn't list a brand name or model but see if there is something coming up on the printer screen when you put in the cartridge or if you can program something in the printer to tell it you changed cartridge.
Dec 06, 2009 | Computers & Internet
Ford Ranger 2.9L Auto low on power
The difference is the 5 speed. He has a lower first gear ratio than you, and probably a different rear end too. You could change your gears, typically a 5 speed is always faster than an auto, typically
Nov 20, 2008 | 1992 Ford Ranger
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
