Question about HP Officejet 5610 All-In-One InkJet Printer
Color and black cartiges will not align
I have replace the cartriges and ran the alignment but I get the color cartridge printing below the black cartridge by about half a line.
  • pressdoc1 Jul 20, 2008
    WHATS THE NOZZLE TEST
  • 26 Answers
Try nozzle test first
Posted on Jul 18, 2008
I have a 5610 all in one printer and when I just put in the new cartiges it gives me an error message stating "Cartige not aligned".
Issue
The instructions displayed on the computer screen during the Print Cartridge Alignment are incorrect. If the printed alignment page is placed on the scanner glass and the Scan button is pressed as instructed on the computer screen, the all-in-one will beep and the control panel display will indicate Busy . The all-in-one will not align the print cartridges.
Workaround
The instructions on the printed alignment page or the all-in-one control panel display are correct. Follow the instructions below: Place the alignment page on the scanner glass and then press the OK button on the all-in-one to complete the print cartridge alignment.
Mar 04, 2011 | HP Officejet 5610 All-In-One InkJet...
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Align the print cartridges
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
cartridges ensures high-quality output.
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
I bought a new color print cartrige and since then my printer align cartridge keeps failing so I can't use my printer. I have reincerted them many times and ran the align cazrtride and I get the same thing...
Sorry to ask a dumb question but did you remove the protective tape on the cartridge when you installed it? If yes, then proceed to the following HP help page where the align cartridge error is outlined along with several solutions. Best of luck!
Greg
OfficeJet k60 Align Cartridge
Nov 06, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
HP 2605dn Black prints 1/8" offset to left. Colors do register
Missalignment problems ae not uncommon with this series of printer.
The cause is one of the sensors (which are used for calibration and alignment) on the transfer belt, is faulty.
These sensors are NOT availale, and replacement of the transfer belt is the solution.
Transfer belt replacement on these printers requires quite a bit of dismantling, its not considered to be a user replacable consumable.
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer cartrige question
Most hp printers print a alignment page when one of the cartridges is changed. If the other cartridge is empty, alignment fails, and printer will not work...
However for most printers is possible a procedure for bypassing a
alignment... if you tell me which printer you have !
Jan 12, 2008 | Office Equipment & Supplies
Cartridge alignment
So if the magenta or yellow are not showing up, it may mean you have installed an empty (or dried up) color cartridge. If you have it, put the "low" volume color cartrige back in and print an alignment page. If you don't have the cartridge, no problem, just print a page from Google. Don't worry about the alignment until you print from Google. See if color is even available. ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Dell 924 All-in-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
